'99 Random Misfire - Ford Truck Enthusiasts Forums
'99 Random Misfire
Old 12-11-2010, 12:05 AM
cs361 cs361 is offline
cs361 is starting off with a positive reputation.
'99 Random Misfire
I started my '99 F250 V10 the other day, and it just ran like crap. It didn't throw a code, but i plugged my reader into it and it gave me a P0300. I have no idea what it could be and all the wires are on the plugs right. There is ZERO power... Any ideas??? Thanks!
Old 12-11-2010, 10:14 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
P0300 is a random misfire.
I bet there's a vacuum leak (the PCV plumbing elbow at the throttle body) or a whole slew of other things. MAF (clean it just to make sure), fuel pressure, you name it.
Old 12-11-2010, 04:36 PM
So where should i start?
Old 12-12-2010, 01:15 PM
sonicblue2003 sonicblue2003 is offline
sonicblue2003 is starting off with a positive reputation.
Well, I fully agree that the PCV elbow can cause a "random misfire" P300 code. I just bought a 99 SD SC 4x4 V10 and it ran like a bag O crap. Decided to throw a set of plugs and known good coils in it and noticed a crack in that PCV hose.
When I removed it , it had two 1" long cracks in it.. Being sunday and all... I carefully cleaned and taped the hose.Monday I will get a new one from the dealer.
Now the truck runs like a million bucks!!!
BTW I just bought this truck for $2500 and everything works.. ESOF 4x4 and all.
Old 12-12-2010, 05:47 PM
So where do i find the PCV Elbow?
Old 12-15-2010, 01:11 PM
SDV10's Avatar
SDV10 SDV10 is offline
SDV10 is gaining momentum as a positive member of FTE.
It is the fat hose running from the bottom of the throttle body(front)to the passenger side valve cover PCV valve. The "elbow" is under the front of the throttle body below your throttle linkage setup.
Old 12-15-2010, 01:14 PM
SDV10's Avatar
Sorry. If you meant the elbow to buy it, they have them at auto zone for 20 bucks.
Old 12-15-2010, 09:55 PM
OK. I am asking because i don't know where to start. Should i start with plugs? Coils? Plug boots? PCV? I'm not sure. I don't want to spend a lot of money to find out something is not the problem. I'm guessing start with something cheap like plugs? Then boots and so on...?
Old 12-16-2010, 12:02 AM
rwchugger rwchugger is offline
rwchugger is starting off with a positive reputation.
P0300
I had the same issue last year. I decided to replace all the COP's, boots, and plugs. Problem solved. I got the COP's on ebay for around $100 for the set of ten. Supposedly those boots are the cheapest route to go as far as replacement/solutions go, but, i bought my rig used and had no idea what the previous owner(s) had replaced. It also had 80k on it. In some forums i've read that any kind of coolant leak or hard water spray will cause the boots to fail and the COP will somehow arc through the boot occasionally, causing the "random" misfires. Good luck
Old 12-16-2010, 06:01 AM
Quote:
I bought the boots at car quest and the plugs. Total for everything was about $80.
The rubber PCV hose was $26 at the dealer. I happened to have a set of coils sitting around since i have friends that work in the engine plant where they build the engine.
Its easier to change the plugs and boots than I thought it would be except the back 2 on the pass side.
Remember, if your not bleeding, your not working... lol
Old 12-16-2010, 09:30 AM
SDV10's Avatar
Mine was running like crap and i cleaned everything i could get to externally. IE new fuel filter, cleaned IAC, MAF, EGR, IAT, and pulled all the boots and checked anddi-electric greased them. One day later the "pending P0300" changed to "P0301 missfire." Replaced cop on number 1 for 32.00 and all is great. All the cleaning took a few hours but cost only 20.00 for the maf cleaner, carb cleaner and di-electric grease. I also checked my pcv elbow first and found it to not be cracked so went on with the cleaning of all those other things. I guess I am saying start with looking at the pcv elbow. You need to remove it to look at it good. Then go on and do MAF, IAC, EGR, and then the boots. Change up the order if you want but that is where I would start. There is my two cents. Out!
Old 12-19-2010, 12:39 PM
My dad's friend is a "Backyard mechanic". But he really knows his S**t. He said that it could have slipped out of time if it is misfiring randomly and also when it starts, it turns over very slow like a car out of time. It cranks almost like the battery is dead. Could this be the problem?
Old 12-19-2010, 01:03 PM
SDV10's Avatar
On this engine there is no timing adjustment. I would think that if it 'Slipped' out of time then it would be pcm or timing chain issue.
Old 12-19-2010, 01:07 PM
Ok... Well then i can rule that one out. I think i'm going to check my MAF today and PCV and plugs, boots and i guess if thats not the problem, i will just have it running, and start pulling COP one at a time to see which one doesn't affect how it runs/sounds
Old 06-27-2012, 07:36 PM
Super99_V10 Super99_V10 is offline
Super99_V10 is starting off with a positive reputation.
Smile
Thanks SDV10 for giving me the idea of checking the PCV elbow. I had multiple issues when I bought this 99 F250 with the V10. hard misfire at first. Threw codes P0174, P0340, P0302, P0300. I didn't know the condition of the plugs and saw that 5 of the COPs were aftermarket. I changed all the plugs, boots, springs and COP on #2 (with new dielectric grease). Cleared the codes and test drove. Miss was not as bad but still there between 1300 and 1800 RPM in overdrive. Threw code P0302 and P0300 so I swapped the #2 and #3 injectors. That cleared the P0302, but still had that P0300 code and it still had that miss. Stumped, I logged in here and saw your post and just like you described, I had a hole in the PCV elbow. I wrapped it with electrical tape and 'wallah' the engine runs perfect. Got the elbow on order.
Spark Plug Coils makthenif 1997 - 2003 F150 6 04-24-2014 08:49 AM
1999 Ranger 6cyl 4.0L 4X4 Misfire dwollum Ranger & B-Series 2 04-13-2014 12:46 PM
Spark plug questions starmilt Modular V8 (4.6L, 5.4L) 15 10-13-2012 05:42 PM
5.4L Plug replacement, and tune up ideas hans2112 1968-2013 Full Size Vans 11 06-05-2012 01:12 PM
99 f350 glow plug problem? kerrys99f350 1999 - 2003 7.3L Power Stroke Diesel 5 02-12-2011 09:45 AM
Tags
46l, 54l, 68, 99, code, cop, f150, ford, misfire, misfore, missfireing, mountaineer, random, v10, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
