Flat spot or tire balancing? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 12-11-2010, 01:00 AM
crabjoe crabjoe is offline
crabjoe is starting off with a positive reputation.
My Expy sat for 2 years and when I recently put it back on the road, I made sure to have my tires balance. At 1st, it felt like I had flat spots in my tires, but now that I've got a thousand miles or so on it, I feel like it's just out of balance now.
I've got a bad vibration from 40-50mph then it smooths back out until I get to about 75mph and there's a vibration again, but only slight at the 75mph+ speeds. Also, it runs fine below 40mph.
So what do you think it is? Can it be that my tires just need to be rebalanced again, since my flat spots are now gone, or is what I'm feeling a permanent flat spot and I should just bite the bullet and get new tires? I just hate the idea of getting new tires because the tires I have on there only have about 10K miles on them and look new!
Thanks!
Old 12-11-2010, 12:43 PM
Big Greenie Big Greenie is offline
Temporarily Deactivated
Big Greenie is gaining momentum as a positive member of FTE.
I would find a shop that offers road force balancing. This will tell you for sure if it is a balance issue or you are feeling flat spots. Usually flat spots will go away after a short drive but 2 years is longer than I have ever let something sit.
Old 12-11-2010, 01:58 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
If you had them balanced when you first took it out of mothballs, the tires have surely changed now that they are getting used and have probably changed a bit. I'd go the rebalance route. The other thing to consider is the age of the tires, not the mileage. Tires generally have a 5-7 year life from the date of manufacture (not the date of purchase - depending on where you got them, this date may be considerably different). You should check the date code on the sidewall just to make sure you aren't spending good money on a set that is due to be replaced anyway.
Old 12-11-2010, 02:42 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
If you have a flat spot or if the belt(s) have slipped you should be able to feel it by running your hands around the tread.
Old 12-12-2010, 08:37 PM
Thanks folks. Tires feel fine and look great! I think I might try a road force balance. I here those Hunter road force balancing machines can't balance a tire with a flat spot because the balance a tire under load. So I figure, if they can balance the tires, I'm good. If not, I guess I'll be looking for some new tires.
Old 12-12-2010, 08:45 PM
Houseworth_t Houseworth_t is offline
Houseworth_t is starting off with a positive reputation.
I would say re balance because when it vidrates at certain speeds that is the main culprit. with vibration at two different speeds seems to be two different tires are unbalanced. If that does not work the obviously bite the bullet.
Old 12-14-2010, 11:35 AM
dirtmonkey11's Avatar
dirtmonkey11 dirtmonkey11 is offline
dirtmonkey11 is starting off with a positive reputation.
I agree with "Big Greenie", the most accurate way to get a tire balanced and checked is to have a tire machine that will put a load on the tire when it is checking/balancing it. That would give you the best results.
Old 12-14-2010, 09:34 PM
bayou barataria bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
I had a truck with heavy duty 10 ply tires that I let sit for about the same time as yours, and when I started driving it again I found that the belts in the tires had settled and I wound up having to replace them. One of them actually threw a tread off and tore up my truck, so check them out good.
Chasing a Vibration Tom Excursion - King of SUVs 25 04-06-2013 08:33 AM
Update on 49mph hop Champ198 6.7L Power Stroke Diesel 55 01-05-2013 11:33 AM
F250 STEERING WHEEL SHAKE, 20 IN WHEELS, NITTO TIRES 2008F250SHAKING 1999 to 2016 Super Duty 8 01-21-2012 12:26 PM
Need some help with what to do - new tires, balanced twice, truck still vibrates bad wogdiml 1999 to 2016 Super Duty 29 11-19-2010 04:52 PM
Vibration @ 49 MPH psmith338 1999 to 2016 Super Duty 15 06-09-2009 02:49 PM
Tags
35, 40, balance, balancing, expedition, factory, flat, ford, machines, motorhome, permanent, spot, spots, spotting, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
