F-350 won't start after oil change and fuel filters changed!!! HELP!! PLEASE! - Ford Truck Enthusiasts Forums
Old 12-10-2010, 08:45 PM
joddo joddo is offline
joddo is starting off with a positive reputation.
i am facing the same problem as of last night now my batteries are dead!! I am charging them again and would like to know if the 2003 F-350 6.0 powerstroke lariat has the fuel shut off button as well!! I am not getting to far with solving this problem and now it has started snowing i was out there till 2am last night up early today and have been trying to fix this all day called ford and did not get too much info! basically I changed the oil and all filters last night, started the truck up and it started up perfectly then after about two minutes it shut down! I cycled it two times before I started it and thought that would have been enough sadly mistaken!! now I for the life of me can not get it started! batteries went dead a few times! now I am on the third charge of the day! PLEASE COMMENT HERE OR EMAIL ME DIRECTLY AT JOHNODDO@ME.COM THANK YOU EVERYONE!
Old 12-10-2010, 09:18 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Quote:
I don't know much about the 6.0, but turn the key to the on position about 5 times before cranking.
There should be a fuel cutoff switch for your truck, If you don't have a owners manual maybe it is located where mine is.
Open front passenger door, look at the side of the dash. If there is a little access door, open it. Should be a switch right there. I think mine is orange or something on top.
Press it down and hold while cranking.
If not there then look down below at the kick panel. Maybe it is there.
Bounds-Electric's Avatar
Bounds-Electric Bounds-Electric is offline
FORD USER
Bounds-Electric is gaining momentum as a positive member of FTE.
I always change frame fuel filter first, start let run , drain top fuel filter!
Did you us ford oil filter? If not try one, I had a after market oil filter that for what ever reason would not let truck start!
Old 12-10-2010, 09:36 PM
yes all ford fuel and oil filters!
now i am not getting fuel to the top fuel filter!
Old 12-10-2010, 09:40 PM
senix's Avatar
with the top filter out, peering into the bowl. If you just turn the ignition to the on position you should hear the pump running. At the same time do you see any fuel entering the bowl?
Old 12-10-2010, 10:13 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Split off and moved to the 6.0L forum. The folks in here should be able to help you a bit better.
Welcome to FTE!
Old 12-10-2010, 10:25 PM
Ok I will look there . I will look for the fuel shut off as well! I can't see it near my glove compartment! Also yes I did use Ford parts and it ran fine for the first few minutes then shut off! and I can't get it started back up! neighbor had the same problem and he said he had air in the fuel lines! I guess I have to find the best way to purge the air out of the lines!
Old 12-10-2010, 10:26 PM
i also put some diesel into the bowl and the ford tech told me to keep the cap closed because of the return!!
Old 12-11-2010, 02:30 AM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
You should be able to purge the lines by turning the key to on, wait 30 seconds with the key in the on position and then back to off. Repeat this about a half dozen times in a row and then try to start. If it does not start repeat the purge process and try starting again. Your going to need the batteries good and charged for this...
If the above ends up failing I would go back and check both caps to make sure the o-rings look good and are seated as one of them could be sucking air. The lower is usually the likely culprit...
Old 12-11-2010, 10:54 AM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Just something simple I haven't seen mentioned yet, but have you checked your oil level. Hate to ask, but you just never know. If that's good I would guess that you have a pinched o-ring.
Old 12-11-2010, 01:11 PM
2006lariat's Avatar
2006lariat 2006lariat is offline
2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation
3 exact threads. 1 in superduty and 2 in 6.0. How about ficm? could the primary (rail pump) have gone bad. Maybe the o ring on frame filter broke and now it is suckin air? maybe crossthreaded rail filter cap. does he have the rail filter in with breather hole to top? did he maybe knock some wires loose on rail pump? does he have fuel in tank (dumb one but ya never know)? Is fuel gelled (didnt read his location)?
Drained batts 3times is probably gonna spell disaster for ficm from what I read on here. Bismic or cheezit or nccpartsman or 1 of the other 6ltr gods will take care of you I am sure. Lots of research on the 6ltr site may help you more too. search for similar threads in here!
Old 12-11-2010, 01:41 PM
pinched O ring was the cause! I put a new O-ring in this morning in the lower fuel filter and the fuel started flowing!! Started rite up!!! Relieved!! thanks for the help everyone! Ya'll ROCK!
Old 12-11-2010, 03:55 PM
senix's Avatar
glad you got it figured out!
Old 12-11-2010, 04:31 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Glad you got it fixed. This issue will be at the fore front of my brain next time I change filters!
Old 12-11-2010, 06:33 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Pinched or damaged O ring on the lower filter has been the major culprit on most filter change no starts. It is very important to lube the O ring with motor oil or vaseline prior to installation. No diesel as it can cause the O ring to swell and bind. The #2 culprit is a/m filters.
74 f350 will not charge Fameus FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-27-2013 03:17 AM
Charging Problems dyingtolive 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 08-01-2012 08:37 AM
Batteries dead over night, Alternator overcharging batteries, confused Nyxlee 1987 - 1996 F150 & Larger F-Series Trucks 10 01-26-2011 10:07 AM
NO START AFTER OIL AND FUEL FILTER CHANGE! STARTED THEN DIED OUT NOW BATTERIES R DEAD joddo 1999 to 2016 Super Duty 10 12-11-2010 01:53 PM
horses stranded!! no start after oil change and filter change! joddo 6.0L Power Stroke Diesel 6 12-11-2010 01:51 PM
Tags
2009, 2011, 73, change, changed, f350, filter, fuel, indicator, oil, power, shutoff, start, stroke, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
