F-350 won't start after oil change and fuel filters changed!!! HELP!! PLEASE!
i am facing the same problem as of last night now my batteries are dead!! I am charging them again and would like to know if the 2003 F-350 6.0 powerstroke lariat has the fuel shut off button as well!! I am not getting to far with solving this problem and now it has started snowing i was out there till 2am last night up early today and have been trying to fix this all day called ford and did not get too much info! basically I changed the oil and all filters last night, started the truck up and it started up perfectly then after about two minutes it shut down! I cycled it two times before I started it and thought that would have been enough sadly mistaken!! now I for the life of me can not get it started! batteries went dead a few times! now I am on the third charge of the day! PLEASE COMMENT HERE OR EMAIL ME DIRECTLY AT JOHNODDO@ME.COM THANK YOU EVERYONE!
There should be a fuel cutoff switch for your truck, If you don't have a owners manual maybe it is located where mine is.
Open front passenger door, look at the side of the dash. If there is a little access door, open it. Should be a switch right there. I think mine is orange or something on top.
Press it down and hold while cranking.
If not there then look down below at the kick panel. Maybe it is there.
Did you us ford oil filter? If not try one, I had a after market oil filter that for what ever reason would not let truck start!
Ok I will look there . I will look for the fuel shut off as well! I can't see it near my glove compartment! Also yes I did use Ford parts and it ran fine for the first few minutes then shut off! and I can't get it started back up! neighbor had the same problem and he said he had air in the fuel lines! I guess I have to find the best way to purge the air out of the lines!
If the above ends up failing I would go back and check both caps to make sure the o-rings look good and are seated as one of them could be sucking air. The lower is usually the likely culprit...
3 exact threads. 1 in superduty and 2 in 6.0. How about ficm? could the primary (rail pump) have gone bad. Maybe the o ring on frame filter broke and now it is suckin air? maybe crossthreaded rail filter cap. does he have the rail filter in with breather hole to top? did he maybe knock some wires loose on rail pump? does he have fuel in tank (dumb one but ya never know)? Is fuel gelled (didnt read his location)?
Drained batts 3times is probably gonna spell disaster for ficm from what I read on here. Bismic or cheezit or nccpartsman or 1 of the other 6ltr gods will take care of you I am sure. Lots of research on the 6ltr site may help you more too. search for similar threads in here!
