460 swap pulley problems - Ford Truck Enthusiasts Forums
Old 12-10-2010, 04:42 PM
mikefender mikefender is offline
mikefender is starting off with a positive reputation.
I am swapping a 460 out of a 74 tbird into a 77 f250 4x4 highboy.
I got a set of pulleys and brackets from a wrecking yard from a 79 F150 4X4 with a 460, alt., a/c and power steering. The only thing I didn't get was the crank pulley as I wasn't equiped to remove it. I have everything bolted up and machined .100" of of the balacer spacer to make the water pump and crank pulleys line up. Now the alt. water pump and crank pulleys line up, but the power steering and a/c do not. Are there a different set of water pump and crank pulleys that will work? Are the 460 water pumps all the same between 74 car and 79 truck? I know that the 74 is internally balanced and the 79 external.
Mike
Old 12-10-2010, 08:44 PM
Never mind, I got a crank and water pump pulley from a 76 truck w/ 460 and now everything but the alt. lines up. I can shim the alt. out.
Mike
highboy 460 swap mikefender 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-11-2009 07:12 PM
460 Pulley Problems hp246 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 06-14-2008 09:47 PM
Water pump pulley interchange? hoxiii 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 12-05-2007 02:31 PM
What have i done? markal Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 02-08-2007 06:18 PM
alternator belt install question green 79 1973 - 1979 F-100 & Larger F-Series Trucks 12 02-20-2004 11:46 PM
Tags
370, 460, conversion, crank, crankshaft, difficulties, ford, highboy, pulley, pully, pump, questions, spacer, swap, swaps, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
