1987 Ford F150 Fuse Wiring Diagram - Ford Truck Enthusiasts Forums
Old 12-10-2010, 11:38 AM
cooktt cooktt is offline
cooktt is starting off with a positive reputation.
Hello all, I recently bought my first F150 (previously had a F100) and I can't find a diagram for the fuse panel on the inside of the cab. Several of electrical components are not working and many fuses appear to be missing. Any help would be appreciated.
Thanks,
Ted
Old 12-10-2010, 12:11 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Here ya go,
Old 12-10-2010, 12:53 PM
Thanks a million!
Old 04-02-2014, 09:44 PM
bonilla_joey bonilla_joey is offline
bonilla_joey is starting off with a positive reputation.
Electrical Nightmare
I just bought a 1987 f-250, 460 motor with a manual trans. I bought it from a tow yard. ( Heres how it started ) 1- I couldnt get the frount tank to work, still has that problem. 2- The starter was real rough when it engaged. 3- after about 200 miles the starter engaged and wouldnt shut off with the key. I replaced the relay on the fender. 4- Windshild wipers came on and wouldnt shut off. 5- Starter came on againand wouldnt shut off even with the key. I couldnt pull over for a minute so it ground the starter gear. 6- I replaced the starter , 1 mile later the starter was back on along with the wipers. I had it towed home.
The harness was melting in certian places. The truck had issues befor doing the same thing ( I found the harnes had been spliced in the same aeras befor)
I'm done whineing, Does any body know about wireing problems with this year truck and can anybody help with wireing diagrams.
Thanks Joey
fuse panel diagram White Boy 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-21-2012 09:02 AM
fuse box diagram vampire Electrical Systems/Wiring 2 10-22-2011 03:52 PM
Fuse diagram BURNSTOUGHFORD 1987 - 1996 F150 & Larger F-Series Trucks 0 11-20-2009 12:18 PM
2000 f150 fuse for a/c blower fan vickieb 1999 - 2003 7.3L Power Stroke Diesel 1 08-07-2009 11:10 AM
1997 Ford f150 4.6 fuse panels diagrams prange55 1997 - 2003 F150 1 03-07-2004 09:44 AM
Tags
12, 1987, 1996, 87, ac, box, diagram, diagrams, engine, f150, f250, ford, fuse, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
