adding engine block heater to 5.4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-10-2010, 11:17 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is online now
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
i want to add a engine block heater to my 04 F-350 with the all mighty 5.4. Did ford offer this as a factory option or do i have to go aftermarket? i would like factory so i know it was meant to be there.
Old 12-10-2010, 11:32 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
If it were me I'd be looking at a lower radiator hose heater. Easy install, and they are supposedly very good for what they are.
Kat's
Old 12-10-2010, 11:33 AM
tigman_tim tigman_tim is offline
tigman_tim is starting off with a positive reputation.
Hi,
I have a OEM one on my 2009 5.4L.
thanks,Tim
Old 12-10-2010, 11:42 AM
i went on parts guy ed web site and i cant even find a listing for a block heater on there? which is strang since a diesel would have one in 04?? ill keep looking
Old 12-10-2010, 11:48 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I would e-mail Ed all the parts are not listed on the site. I'm almost 100% positive a factory option for 04' was a block heater for the 5.4l or 6.8l. The guys in northern climates need them.
Old 12-10-2010, 11:51 AM
thanks crazy, their product looks well made. brass plug with o ring ill give them a call
Old 12-10-2010, 11:52 AM
i would think they would. i just want a price and ill get a price from kats company and my local dealer. money is funny and whoever is cheaper ill buy it there.
Old 12-10-2010, 12:18 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
Quote:
F7UZ6A051BA BLK HEATER
1C3Z6B018BA CORE
Old 12-10-2010, 01:30 PM
is the core the heating element?
Old 12-10-2010, 11:09 PM
5.4f250sd's Avatar
5.4f250sd 5.4f250sd is offline
5.4f250sd is starting off with a positive reputation.
This is what I did this summer. I have yet to use it but it tested out great. I used to run a hose heater on my last truck but I was nervous with the way the lower radiator twists. It worked out great and I would do it again in a heart beat.
http://www.ford-trucks.com/forums/99...t=block+heater
Old 12-11-2010, 12:18 AM
sotwclarinetguy sotwclarinetguy is offline
sotwclarinetguy is starting off with a positive reputation.
The block heaters are much better than the hose heaters, as the hot water does not leave to the radiator as quickly. The stock location is the LH rearmost softplug. Easy to install, too.
Old 12-11-2010, 03:20 AM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
If you want to take a economical approach you could buy a ZeroStart (Phillips & Temro) Part Number 3100040 which is a block heater kit that would give you the same element as OEM (P & T is Ford's supplier), but the cord would be a generic one that you would have to route and tie-up as you choose. Some place like NAPA should be able to get this to you for about $25.
Or the OEM approach...
Heater/Element Assembly (MSRP $27.48): F7UZ-6A051-BA
Wiring Assembly (MSRP $78.63): 1C3Z-6B018-BA
Old 12-11-2010, 12:01 PM
illini5190 illini5190 is offline
illini5190 is starting off with a positive reputation.
I guess the real question is how bad would it be to install the freeze plug type block heater. I have heard horror stories about them leaking. Has anyone had experience with putting one in?
Old 12-11-2010, 08:36 PM
It is not bad at all:
1. Drain the coolant from the engine block.
2. Remove the soft plug with a hammer/ punch/ screwdriver/etc. Try to just knock it sideways in the hole, instead of into the coolant jacket (although it is not a big deal if you do). This makes it so you can put pliers on the edge of the plug to pull it out.
3. Clean the bore of the softplug hole with some fine emery cloth (like 320 grit) as necessary to remove water scale, rust, or debris and rought spots from the bore. This is important.
4. Apply a small amount of oil or grease to the o-ring of the new heater element. Do not apply sealant as it DOES NOT help in the sealing process. Lubricant just prevents cutting the o-ring as it goes in the bore.
5. Insert the heater in the hole. Make sure the element part of the heater is not touching any part of the block once installed. Vibration from touching the block will eventually break the element.
6. Torque the center screw of the element to the SPECIFIED TORQUE, usually around 15-25 inch pounds. Overtightening is the most common cause of failure, with undertightening following a close second. Too tight squishes the o-ring out, and under tightening does not seal the o-ring to the bore.
7. Route your cord, fill it with coolant, done.
These are really easy to install, we do about 50 of them a year through our shop. The work really reliably as well. Good luck!
Old 12-12-2010, 01:50 AM
5.4f250sd's Avatar
I can say that I am bias to this post because a hose heater may leach heat off to the radiator but my hood on my last truck never ever held snow on it which means that the engine compartment was above freezing.(Ideal conditions) I can say that the frost plug heater in my particular motor is a great choice because there is not place to put a hose heater that allows gravity to circulate the heat through the motor like it should. Oh and the install was as easy as it gets! Read my above post for more details!
Need engine block heater advice 2gumby2 2015+ F150 11 04-06-2016 12:30 PM
OE block heater non-operable bbender85 2004 - 2008 F150 6 02-16-2015 01:04 PM
Factory Installs Block Heater Element On All 5.4's ? ironmine 1999 to 2016 Super Duty 29 11-26-2012 03:21 AM
Block Heater - Tripping My GFI seville009 1999 to 2016 Super Duty 35 01-21-2007 11:06 PM
Navigator Engine Block Heater DTL504 Expedition & Navigator 6 01-27-2005 11:02 AM
Tags
2004, 2011, 54, block, diesel, duty, engine, f250, ford, heater, heavy, installing, kit, location, motor, phillips, truck, zerostart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
