1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
adding engine block heater to 5.4
Old 12-12-2010, 01:06 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Originally Posted by PowerStrokeHD
If you want to take a economical approach you could buy a ZeroStart (Phillips & Temro) Part Number 3100040 which is a block heater kit that would give you the same element as OEM (P & T is Ford's supplier), but the cord would be a generic one that you would have to route and tie-up as you choose. Some place like NAPA should be able to get this to you for about $25.
Or the OEM approach...
Heater/Element Assembly (MSRP $27.48): F7UZ-6A051-BA
Wiring Assembly (MSRP $78.63): 1C3Z-6B018-BA
100% Agreed
Don't fool around with the KATS brand products they are junk read the reviews of them all over www.amazon.com they all fail or seem to leak within months. Go with a P & T also sold as ZeroStart or HotStart heaters.
Old 12-12-2010, 12:52 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
thanks im just gonna order an oem one from ed
Old 12-12-2010, 04:45 PM
Millenium Edition's Avatar
Millenium Edition
Millenium Edition is offline
The KATS heater has always worked well for us, however we have them installed on a 4020 and 4520 John Deere.
Old 12-12-2010, 07:06 PM
sandmanf250's Avatar
sandmanf250
sandmanf250 is offline
block heater in a gas motor
you don't need it if your running the right oil,
Old 12-12-2010, 07:35 PM
towya88's Avatar
towya88
towya88 is offline
Go the OEM route, easy to install and works great . Live in Michigan and its nice for starting up on cold mornings.No problems with leaks and is well worth it!
Old 12-12-2010, 11:00 PM
illini5190's Avatar
illini5190
illini5190 is offline
Well after all of the horrors stories I have heard that was very reassuring. I just wish I would have tackled this before it started snowing. Probably a project for next spring. Thanks!
Old 12-13-2010, 09:38 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
Old 12-13-2010, 10:53 AM
SuperDutyScaler
same here illini, ill order it soon but im not draining the radiator fluid when its twenty degrees outside plus i just did it this summer! i gotta plan things out better
Old 12-13-2010, 11:46 PM
illini5190's Avatar
illini5190
sotwclarinetguy - Do you guys get the plug heater from Napa etc. or order them OEM?
Old 12-14-2010, 12:45 PM
SuperDutyScaler
im gonna order oem when im ready soon. i just dont want to install it when its 15 degrees out right now and lose the new fluid i just flushed out this summer
Old 12-14-2010, 08:11 PM
sotwclarinetguy's Avatar
sotwclarinetguy
sotwclarinetguy is offline
We use both, with pretty good success. It is mainly the installation that determines how well they work. Good luck!
Old 02-10-2011, 12:08 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
I'm starting to wish I'd done this...
-18F this morning, and I started to have a little trouble turning over.
I think the transmission oil was to blame... whoever decided a circulation pump and a cooler in a manual transmission were a good idea wasn't the brightest bulb on the string. All I got to hear this morning was pump cavitation as she warmed up.
  #28
Old 02-10-2011, 02:14 PM
5.4f250sd's Avatar
5.4f250sd
5.4f250sd is offline
I hear you. I have used mine this winter! I was up north of me where the temp was -38 and with Amsoil and my block heater it turned over like it was 80 out side. Only thing was my power steering pump was crying at me for a couple minutes. I am running synthetic in that too. All in all, Im very happy I installed one this fall.
Run to napa, pull it into the garage and be done with it in about 45min. My 2 cents! Oh but wait for it to get above freezing!
  #29
Old 02-10-2011, 02:38 PM
alwayschooseford's Avatar
alwayschooseford
alwayschooseford is offline
I have a lower radiator hose heater, it works great and it was only about $30 at O'Rielly.
lhud
12-23-2016 12:47 PM
2gumby2
2015 - 2020 F150
04-06-2016 11:30 AM
khxor
12-09-2015 10:08 AM
Joe Lallande
2015 - 2020 F150
09-01-2015 08:58 AM
ironmine
29
11-26-2012 02:21 AM
Quick Reply: adding engine block heater to 5.4
