Rear axle oil change - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-09-2010, 10:11 PM
Boatbum01's Avatar
Boatbum01 Boatbum01 is offline
Boatbum01 is starting off with a positive reputation.
I would like to change the oil in the rear axle and also in the front axle.
What are my choices as to oil, regular and synthetic, and how much friction modifier additive should I use? Do I need to flush the housing if I change to synthetic?
F250 SD 7.3l 4 x 4 XLT supercab
Thanks,
Jim
Old 12-10-2010, 01:32 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Jim,
the back axle will have synthetic from factory, so you will want to stay that way. I went with lucas when I changed mine because that was all I could find locally. Royal purple is a favorite, and has the friction modifier in it already. You will want to first find out if you have an open or limited slip diff before adding any modifier. It is also a good time to look into replacing the back cover with the 08+ alum finned cover. You can use guzzle's site for instructions and tips. Welcome to guzzle's Ford PSD Maintenance Web Page
Old 12-11-2010, 01:18 AM
rymac320 rymac320 is offline
rymac320 is starting off with a positive reputation.
I did my front without any problem a month or so ago..Ford now reccomends 75W-140 synthetic for front and rear.... tried to do the rear yesterday and could not get the cover to come off! going to wait a few months until it warms up and i can spend some more time, probably going to take out the spare tire too for more room. but overall a simple process. i used the factory motorcraft.
Old 12-11-2010, 01:41 AM
rickf92592 rickf92592 is offline
rickf92592 is gaining momentum as a positive member of FTE.
You can mix synthetic and regular no problem.
+1 on the alum cover.
Old 12-11-2010, 10:49 AM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Mobile1 75W-140 synthetic.
Just did mine a couple months ago.
Rear axle fluid 96DRW 1999 to 2016 Super Duty 5 07-25-2012 01:40 PM
need advice on rear diff oil change. Max1 Ranger & B-Series 5 06-15-2009 11:04 PM
Is 5w-20 what to use? Jimmygator Oil & Lubrication 15 01-02-2008 04:15 PM
synthetic lubes tyrfryr Oil & Lubrication 27 11-10-2004 03:33 PM
F250 HD (1997) 4X4 front axle gear oil recommendation jim692 1997 - 2003 F150 2 10-25-2000 06:30 AM
Tags
2002, 99, axle, back, change, drain, end, excursion, f150, f250, fluid, ford, oil, rear, rearend, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
