1996 F-150 XLT Steering Column $ & Directions - Ford Truck Enthusiasts Forums
Old 12-09-2010, 08:35 PM
Barry Eck Barry Eck is offline
Barry Eck is starting off with a positive reputation.
What is a good price to pay for a Steering Column complete with tilt wheel and the air bag taken out ready to go with the keys? How difficult is it to take out? I've taken out one before on a 1989 F-250 with out the Air bag or any of the extras.
Thank you for you advice and direction.
Old 12-09-2010, 10:06 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
I don't know what is reasonable to pay, but the local yard got me for $75 for the tilt column, matching keys, non-deployed air-bag, the signal stalk and flasher switch, and the ignition switch.
I got my column out of an older town car though, but I imagine if I pulled a truck column it would have been the same price, because mechanically they're basically the same thing.
I forget if it has two or four bolts holding it onto the aluminum mount, but the nuts are facing down so it's just the matter of taking those off and undoing the bolt that holds the u-joint at the bottom together, and disconnecting the electrical connectors or cutting the wires on the harness side if you want snips.
I can get one out in about 15 minutes if my tools are on the floor of the truck.
Old 12-10-2010, 01:51 PM
Frederic, Thank you for the information that is helpful and that price is right in line what I was thinking.
Thanks again
Replacing Steering Column terrylamar 1994.5 - 1997 7.3L Power Stroke Diesel 2 04-11-2016 08:30 PM
Steering column and steering box change Cazman1955 1961 - 1966 F-100 & Larger F-Series Trucks 0 02-01-2016 05:12 PM
Steering Wheel Lowdog 1978 - 1996 Big Bronco 6 03-29-2014 03:59 AM
1996 f-250 Steering Column Sandyandman1 1987 - 1996 F150 & Larger F-Series Trucks 5 01-06-2011 01:34 PM
Loose Steering Column 99 Ford Explorer TriciaKow Explorer, Sport Trac, Mountaineer & Aviator 1 04-02-2006 07:31 PM
Tags
150, 1996, 96, barry, column, eck, f150, ford, forum, ma, norton, steering, truck, xl, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
