Instrument Panel Bulb - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-09-2010, 03:44 PM
Justin's Green Truck's Avatar
Justin's Green Truck Justin's Green Truck is offline
Justin's Green Truck is starting off with a positive reputation.
Hi I am working on a 2003 Escape. One of the bulbs in the instrument cluster has burned out and needs replaced. Does anyone here know how to remove the cluster? Any pics of one being removed? Tools needed? Thanks for any info
Old 12-09-2010, 09:44 PM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
I also have an 03 Escape and the bulb that lights up the odometer has been blown out for the longest time.
I think somewhere on here someone posted everything, diagrams and step by step instructions on how to remove the cluster. If I remember correctly it really wasn't that hard.
Hopefully someone will post the url for this. I would like to have my odometer light back.
Old 12-09-2010, 10:01 PM
DaveinRoswell DaveinRoswell is offline
DaveinRoswell is starting off with a positive reputation.
Howdy Folks,
I just changed my odometer bulb a month ago, it was pretty painless.
First thing I did was disconnect the battery. Then I lowered the steering wheel as low as it could go. There are two phillips screws that hold the the trim in around the instrument cluster at the top, take them out and the panel.
At that point there are 4 small bolts that hold the cluster in, 7mm or something close to that. Take them out and then carefully lean the cluster top towards you, and even more carefully ease out the the two electrical connectors, because you do not want to break or bend any of the pins.
After disconnecting the two connections, pull that cluster out of there and change your bulbs. The only other advice I would give is to ground yourself before touching the circuit panel the bulbs are mounted on behind the cluster, and try not to scratch that board.
Dave
Old 12-10-2010, 07:15 PM
Quote:
Originally Posted by DaveinRoswell View Post
Howdy Folks,
Dave
Thanks Dave! I copied and pasted your instructions into a WORD document. Gonna try it next spring when the weather breaks. Does sound pretty straight forward. Thanks again.
Old 12-14-2010, 09:42 PM
aj7885 aj7885 is offline
aj7885 is starting off with a positive reputation.
here is the link to my original post. One note I should have added was to unplug two wire harness at top of cluster to pull it out forward.
http://www.ford-trucks.com/forums/63...splay-out.html
Old 12-15-2010, 06:12 PM
Thanks for the tip! Sounds easy enough...
Old 12-16-2010, 07:52 AM
scottss80 scottss80 is offline
scottss80 is starting off with a positive reputation.
This really is a very easy fix. When I replaced mine I kicked myself for not doing it sooner!
Need instructions to remove instrument cluster to replace bulbs proudfrog Excursion - King of SUVs 2 05-11-2015 08:22 PM
2006 E350 Super-Duty Instrument Cluster Bulbs surgesound 1968-2013 Full Size Vans 5 04-24-2015 07:32 PM
instrument cluster removal jayrus544 2004 - 2008 F150 3 05-20-2011 09:07 AM
Dash light replacement sorensenj Ranger & B-Series 5 11-10-2008 09:12 AM
98 EXP - Change instrument panel bulbs erbenson Expedition & Navigator 10 02-04-2007 01:26 PM
Tags
01, 2003, bulb, cluster, dash, escape, ford, instrament, instrument, light, odometer, panel, removal, remove, speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
