oil cooler leaking - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
oil cooler leaking
Old 12-09-2010, 02:36 PM
jg96powerstroker's Avatar
jg96powerstroker jg96powerstroker is offline
jg96powerstroker is starting off with a positive reputation.
oil cooler leaking
ok i have seen some oil spot latly, and looked under my truck the front of the cooler is covered with oil and the 2 front lines going in it, the rest looks clesan as well as the top lines, i was it off and same thing, to day i seen a little antifreez in the oil so must be getting wors, can i use a sd oil coler ? are thes a pain to rebuild and replace, looks like 4 lines and 4 bolts, is there a good place to get orings or a new cooler? any picks would be a big help thanks guys!!!
Old 12-09-2010, 03:19 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is gaining momentum as a positive member of FTE.BadDogPSD is gaining momentum as a positive member of FTE.
You can buy the rebuild kits from riffraff or dieselorings.
Messy, but something you can do yourself. New coolers are
very pricey, the rebuild kits are around $60.
Old 12-09-2010, 04:13 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Old 12-09-2010, 04:17 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Are you sure your looking at the oil cooler? Last I checked the oil cooler has no lines going to it..
Old 12-09-2010, 04:23 PM
ok will get a kit, but will a sd or idi oil cooler fit?? saw some on eday for 60 buck, wanna get one rebuild it then take myn off and put new one on, its my every day truck so cut down time down, how big of a pain are these ?? what is it take time wise?? thanks
Old 12-09-2010, 04:27 PM
Quote:
yeah it must be fuel lines i just washed it off at the car wash, and it has to line at the front and you can see two lines throw wheel well, but they have the fuel line conecters, but the cooler only is leacking from the front is that where it usaly happens??
Old 12-09-2010, 05:01 PM
BadDogPSD's Avatar
Here's a couple of how-to write ups... everything I do seems to take twice as long and cost twice as much!!!
7.3 oil cooler rebuild - TRT Home
Oil Cooler O-ring replacement R and R - Powerstroke Nation
Old 12-09-2010, 06:17 PM
Your oil cooler should have nothing running to it except for the block heater cord on the back oil cooler cap... You can use an oil cooler from a '94.5-'03.
Get a rebuild kit from Clay. He gave you a link to them in his reply above.
Old 12-09-2010, 09:58 PM
yeah the lines run over top of it i thought they went to it my bad, is there any gain from the sd oil cooler?? i have a oring set on the way. thanks guys !
Old 12-09-2010, 10:28 PM
Nope, no gain in the SD cooler...
Old 12-09-2010, 10:30 PM
lol come on man you could have said 5 or 10 hp gain. lol thanks man
Old 12-09-2010, 10:50 PM
Krisx125's Avatar
Krisx125 Krisx125 is offline
Krisx125 is gaining momentum as a positive member of FTE.
Just checked over at powerstrokehelp...SD oil cooler helps gain 30hp over stock.
Old 12-09-2010, 10:56 PM
Quote:
sweet now thats what i wanted to hear! lol think i can grt 35 0r 40 out of her?? lol
Transmission cooler line fittings djustin973 1967 - 1972 F-100 & Larger F-Series Trucks 5 04-09-2015 03:24 PM
Little Oil Cooler write up!!! strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 64 11-10-2012 05:14 PM
Oil cooler removal Podaso 1997 - 2003 F150 3 03-15-2011 01:28 PM
Install Oil Cooler on Oil Bypass Out Port?? zmanmike 6.0L Power Stroke Diesel 7 12-15-2010 11:40 PM
Oil cooler lines -- for remote oil filter ebraunusa Expedition & Navigator 18 12-14-2010 12:20 PM
Tags
73, 73l, 95, 96, ccv, cooler, f250, ford, gain, hp, leak, mod, oil, riffraff, spring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
