replaceing the bed on my 1985 ford f150 - Ford Truck Enthusiasts Forums
Old 12-09-2010, 12:20 PM
wvdreamer wvdreamer is offline
wvdreamer is starting off with a positive reputation.
Smile replaceing the bed on my 1985 ford f150
Need to get the bed replaced and having a horrible time, i'm a complete novice at this type of stuff! i was told that other years might work for the truck instead of just saying absolutly that year model, is that true and if so, which years? thanks
Old 12-09-2010, 01:13 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
1980 thru 1986 are an exact match, while 1987 to 1996 will fit, but lacks the matching wheelwells of the 80-86. If changing to a different year, be aware of changes made to the tailgate hinges/latches/straps or cables. 80-82 uses a different tailgate than 83-86, and the 87-96 beds would need the matching gate, but there are 2 different types. I'm not sure of the exact year the change was made.
Old 12-09-2010, 01:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
All boxes 1980-1996 will be a direct bolt in swap.
Only 6 bolts holding it to the frame.
Bolts are most likelly rusted on, grind the heads off, remove bed, get rest of bolts off frame, replace with new ones. Really easy.
1978 F-150 Bed Replacement bigred513 1973 - 1979 F-100 & Larger F-Series Trucks 16 03-25-2015 09:17 PM
What bed will fit jelzy 1994.5 - 1997 7.3L Power Stroke Diesel 4 08-14-2013 02:00 AM
64 f100 short bed bed replacement Dmansnyd 1961 - 1966 F-100 & Larger F-Series Trucks 9 04-25-2013 04:38 PM
1993 ford f350 sattamassagon 1987 - 1996 F150 & Larger F-Series Trucks 5 05-17-2011 09:11 AM
87 f150 bed swap Bigblza 1987 - 1996 F150 & Larger F-Series Trucks 6 09-20-2003 08:13 AM
Tags
1985, 85, bed, f150, ford, removal, replacement, swapping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
