96 f-350 no odometer - Ford Truck Enthusiasts Forums
Old 12-09-2010, 09:20 AM
jojo saw jojo saw is offline
jojo saw is starting off with a positive reputation.
my odometer numbers dont show up, what is the cause and how is it fixed? thanks.
Old 12-09-2010, 09:28 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You may have a bad fuse, it would be fuse #8 or #18 in you cab fuse panel.
I could also be a bad ribbon cable or PSOM.
Old 12-09-2010, 09:53 AM
96f350az's Avatar
96f350az 96f350az is offline
96f350az is gaining momentum as a positive member of FTE.96f350az is gaining momentum as a positive member of FTE.
is it sifting really hard to? if so its the fuse. had this happen to me scared the living sh*! out of me. haha good luck
Old 04-21-2011, 06:46 PM
got truck all together, still no odometer, all fuses check out ok. how do i determine between ribbon cable or psom. took the dash apart and when u touch the cable some numbers start to appear but instantly go away.
95 Aerostar - Electonic Odometer & Speedometer not working jim33067 Aerostar 4 01-29-2014 10:01 PM
odometer question? bcaughhorn 2004 - 2008 F150 0 05-15-2013 09:47 PM
odometer question Greenmachine_76 1987 - 1996 F150 & Larger F-Series Trucks 2 02-16-2010 10:29 PM
odometer question Greenmachine_76 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 02-16-2010 06:43 PM
1999 f150 odometer wrenchboy 1997 - 2003 F150 6 01-30-2001 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
