Melted 2009 6.4L Powerstroke - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 12-09-2010, 12:26 AM
jake1979 jake1979 is offline
jake1979 is starting off with a positive reputation.
1st Diesel vehicle purchased and followed the dealer recommended oil change intervals of 10,000 miles. While starting up a very steep grade I lost traction and shifted into 4-high and when the tires caught it felt like the tranny dropped and the engine started running like S.
Turns out engine melted down at 30,800 miles (#2 & #8) – Ford engineer denies warranty due to lack of maintenance. Engineer tells me I should have been changing the oil at 5000 or 200hrs and I should of had 5 oil changes at this point instead of 2. Engine failure is due to oil growth from lack of maintenance causing the oil to be sucked up into the charging system.
Dealership claims no responsibility for the service recommendations they gave me.
Any Advice?
UPDATE-
Sorry guys, I need to clarify. I let off the pedal and the truck was still moving up the hill but the tires were not spinning (this is not my first 4x4).
The engineer from Ford came back with a report stating that the fuel growth from the regen process had gotten to the point where oil was sucked throught crankcase breather system and then fed into the air intake system as a uncontrolled fuel source. Basically ford and the dealership are giving me the finger stating that based on the hours of my rig I should of had 5 oil changes instead of 2.
What I think might of happened is that the breather system that injested the oil is located towards the flywheel and when the tires grabbed in 4wheel drive and I was going up the steep road all the oil ended up at the back of the engine.
Thanks for all the feed back, I really appreciate it!
Old 12-09-2010, 12:31 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Not sure if this post is a hoax or not? sucked up into the charging system??????
Old 12-09-2010, 12:47 AM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
I can't recall - do the 2009's have oil change warning lights?
Call the Ford Customer Relationship Center: 800-392-3673
Old 12-09-2010, 01:10 AM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
Quote:
Turns out engine melted down at 30,800 miles (#2 & #8) Ford engineer denies warranty due to lack of maintenance. Engineer tells me I should have been changing the oil at 5000 or 200hrs and I should of had 5 oil changes at this point instead of 2. Engine failure is due to oil growth from lack of maintenance causing the oil to be sucked up into the charging system.
Any Advice?
1. NEVER shift into 4WD when the tires are slipping. Front and rear must be turning at the same rate to avoid serious damage.
2. Look in your owners manual for the oil change interval suggestions. If one of them says 10,000 miles, you have a leg to stand on.
Sounds pretty fishy to me. Did the truck in question have a tuner or mods done to it?
Old 12-09-2010, 01:38 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
I say sue the dealer and salesman that sold you the truck. A lot of salesmen sell cars on 40mpg and 10k mile service intervals. It's about.time they take responsibility.
Old 12-09-2010, 01:44 AM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Sounds like a hoax. I run mine 10K between oil changes with no problems. Although, I don't switch into 4WD while spinning the tires...
Old 12-09-2010, 01:55 AM
lariat79sc's Avatar
lariat79sc lariat79sc is offline
lariat79sc is starting off with a positive reputation.
At any rate there was oil in it, and the engine went supposedly. Enough said to me. I'd be on the horn with everyone to get me a replacement. What a bummer. Good luck...
Different dealers different results: my 97 F150 had a cracked door seam. My friends 99, same thing. His dealer replaced his door under the 100k rust and corrosion warranty, mine told me to go to hell. Don't do business with that dealer anymore.
Old 12-09-2010, 07:11 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
I've heard some weird stuff about the 6.4s but never about crankcase oil getting sucked into the charging system......
Old 12-09-2010, 07:37 AM
spud57's Avatar
spud57 spud57 is offline
spud57 is gaining momentum as a positive member of FTE.
Somthing's just ain't right. Ford's Fleet website does say 10K for oil changes for the 2009 6.4.
Side note - never shift on the fly when the wheels are spinning!!!
Old 12-09-2010, 08:03 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
sounds like he was 'making oil' due to regen and the crankcase filled.
which can and has happened. Many of us use the special Short Stick method of checking our oil to prevent this over-fill condition.
http://www.ford-trucks.com/forums/82...ml#post7189293
we are also using the severe duty oil change maint cycle at 5,000 miles to help avoid this condition.
all that said, I don't see how they can deny if the recorded maint is as documented. so, I'd call the for 800 customer service number. be prepared to provide the documentation on service of course.
Sam
Old 12-09-2010, 08:07 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Hmmm making oil is not the cause therefore call ford cust svc...most likely the dealer is saying no warranty not ford.
clearly 10K oil change intervals are allowed.
This oil in the charging system...so it got in the alternator did it? Clearly the op does not do his own maintance..so the dealer should have all records and ford cust svc can access them.
Old 12-09-2010, 08:16 AM
sdetweil's Avatar
I'm assuming the OP, as a first time diesel owner, also doesn't use the terms we have come to learn here. so 'oil growth' and 'sucked up' were the two key phrases for me. Likely the 2 & 8 injectors stuck for some reason (fuel filter problem, water, ...) causing the over full condition.
Sam
Old 12-09-2010, 08:26 AM
rjfetz1 rjfetz1 is offline
rjfetz1 is gaining momentum as a positive member of FTE.rjfetz1 is gaining momentum as a positive member of FTE.
Dealers get away with a lot of crap....my wifes bmw manual says change oil every 15k.. well with 72k on her car and engine trouble guess what the dealer said? You should have changed the oil every 7500k cuz you need a new motor now. Took it to the shop i take my truck to and they solved the issue. Now have extended protection on her engine as well as mine.
Old 12-09-2010, 08:30 AM
senix's Avatar
Good thoughts Sam.
Maybe he will report back with more info.
Scott
Old 12-09-2010, 09:43 AM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Quote:
I hear you. Anybody else smell fish? Maybe the same fish smell as another new posters thread about multiple 6.4 issues.
6.9 idi review and info F-250 XL DIESEL 4x4 4 SPEED LOCK Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 65 09-20-2016 12:02 AM
MY SUMMER TRIP 9400 MILES OF FUN StanleyZ 6.7L Power Stroke Diesel 15 08-29-2015 01:06 PM
Has anyone backflush oil cooler with a pond pump? Marine tactic... ShawnQ 6.0L Power Stroke Diesel 1 09-23-2014 12:36 PM
What lessons did Ford learn from the 6.0/6.4 for the 6.7? gearloose1 6.7L Power Stroke Diesel 31 02-22-2011 09:58 PM
Tags
2009, 525, 64, bend, change, engine, guide, intervals, mcgregor, melted, oil, owners, pistons, powerstroke, recommeded, sienna, trail, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
