Melted 2009 6.4L Powerstroke
#61
Have they mentioned specifically why they won't pay?
i.e. they felt you didn't check the oil frequently enough
My suggestion is to write a letter to the customer service center (or Mark Johnson directly)
Outline everything.
- Mention when you purchased the truck, and the miles it has on it today
- Document the oil changes you have done per the manual (also mention they were done at the dealer).
- Mention your loyalty to the company (i.e. past trucks you have purchased)
- Mention the failure symptoms you noticed when the problem occurred
- Mention the # of days you have had the truck off the road
- Feel free to cite the positive and negative experiences you have had with Ford Representatives throughout.
My personal experience is that Ford are usually pretty reasonable when it comes to things like this, and I am genuinely surprised if the story is as you say it is and it hasn't been approved.
#66
issues with ford trucks.
The ford truck has had some issues but, the people that dont service them properly are the ones to blame.........
I have a few of the 6.4L and few of the 6.0L and also one 7.3L and also other manufacturers trucks I have always done my oil changes at 5000KM or 3MONTHS......
#67
#68
You might enjoy the EPA report on Bio diesel and DPF equiped motors. It's under my signature on 13 December 2010 or very near that date. I couldn't find a report without bio but I think this report may also address ULSD.
#69
What's a charging system anyway?
I think people are misreading the op's comments. When he says the oil was sucked into the "charging system", I understand it to mean the turbocharger.
A Turbo Charger is an air charging system or 'forced induction'.
Turbocharger 'charges' the cylinders with air.
Considering this, and the structure of the engine, I could conceive that engine oil would be drawn into the turbo intake through the PCV, due to higher than usual oil, steep grade, road conditions and of course, oil growth.
Furthermore, it is possible for an injector to be stuck open.
Also, if a truck is regenerating too frequently, this could cause oil growth as well.
In addition, let's not forget that all people, no matter how well trained, make mistakes. It may very well be that the tech who did the oil change overfilled the crankcase.
All in all, I wish op the best and hope that ford can rectify this situation.
#72
This is possible sucking oil from the crankcase into the intake due to oil being over filled caused by regen. Happened in my truck today, done the Dpf delete with the DPF-R 4.0 stacked with superchips programmer on performance. Took it for a hard run did great then a cloud of bluish smoke was coming out of the truck. Let it cool down shut it off checked oil (overfilled) pulled crankcase vent hose oil in it of course being sucked into the intake. Changed oil filled to correct level no more oil sucking or smoke.
Leroy Unlisted
65
09-19-2016 11:02 PM
annaleigh
04-19-2016 02:28 AM
