Melted 2009 6.4L Powerstroke - Page 4 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #46
Old 12-09-2010, 08:39 PM
jake1979 jake1979 is offline
jake1979 is starting off with a positive reputation.
Customer Service
After dealing with the call center I was finally assigned an escallated customer service rep. Mark Johnson is his name and he has been a stand up guy and has been awsome with communication. Yet Mark has not been able to help Ford is sticking to their guns.
  #47
Old 12-09-2010, 08:41 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by jake1979 View Post
#2 Was down to 150psi
#8 Was down to 60psi
I wish I could upload pics of the engine and my truck!
This whole thing has been going on for 2 months now and the dealer and Ford wants me to pay for the replacement engine.
Everyones support has givin me the energy to fight another day on this thing. I've got a voicemail from the service manager of the dealer admitting that his guy put 10,000 on my oil change interval sticker. His comment to that problem was "sorry for the inconvenience".
Update: Buy the way it looks like you might be the FNG if you don't think you could melt down the pistons in your Truck!
To post pics, load them to photo bucket.com, them link to them from here. Fte sets 25 posts before you can do anything useful here.
Would like to see the pics
Sam
  #48
Old 12-09-2010, 09:04 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Subscribing to see the pics.
The loud bang could have been anything, especially when shifting into 4wd while moving.
The dealer story you've told us makes it sound like you had a runaway engine (rpm's at redline when foot off the go pedal) but you're saying that didn't happen. If the engine didn't run away, then nothing being sucked up by the intake from the CAC or CCV is going to melt any pistons.
Follow Adrain's suggestions of who to talk to next or what to say to the service center.
  #49
Old 12-09-2010, 09:42 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I've got run around by all Ford levels when dealer drop the air filter clamp into my turbo passages. Fortunately I was able to fix turbo myself with low cost.
The run away story reminds me the Detroit 8V71 I do have in my motorhome. The diesel engine is 2-cycle but has similar design with injectors under the valve covers.
The situation never happened to me, but those Detroits are know for running away, so I do have a switch on dashboard with a cover like military missile do have on their switches. The switch releases a big flapper that completely close the intake shutting the engine off till you go back there (it is diesel pusher) and reset the flap manualy.
Maybe Ford should follow the old design?
  #50
Old 12-09-2010, 10:06 PM
SandR's Avatar
SandR SandR is offline
SandR is gaining momentum as a positive member of FTE.SandR is gaining momentum as a positive member of FTE.
Just wondering - if you change the oil and filters every 5k miles, is it possible to 'make' enough oil to cause engine failure?
  #51
Old 12-09-2010, 10:36 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I didn't start running away for at least a mile (pretty much when I got to a place where I could pull over).
Quote:
Huh? I think he is saying it did runaway.
The runaway may have been in progress already, but you didn't really hear it until you unloaded the engine.
Do you know if the crankcase was flooded? Did you actually check the oil level before turning it over to Ford? How long since the last time you checked the oil level? I believe the owners manual instructs you to check oil level each time you refuel. I don't think anyone could reasonably blame you if you didn't do that, but the instruction is there.
  #52
Old 12-09-2010, 10:47 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Without knowing the OP's driving habits it's difficult to say which was technically the correct schedule.
I agree with Cheezit, and I always changed my 6.4L oil at 5,000 miles regardless. But you should NOT have to be a member of FTE and read these threads to know that; what's said in the diesel supplement should be sufficient.
So if your driving truly wasn't severe service then I believe Ford should cover it.
This is not to say that I think they WILL cover it, as we've heard how Ford can blame the owner for lack of maintenance.
All you can do is protect yourself. Follow the severe service schedule, check your oil regularly, and prove that you took every reasonable precaution in the maintenance of the truck.
Sorry to hear about your luck, that's a tough pill to swallow.
  #53
Old 12-09-2010, 11:45 PM
Machinator Machinator is offline
Machinator is starting off with a positive reputation.
Quote:
Originally Posted by mailman01 View Post
So, if I understand this correctly, even if I use the truck for routine purposes, no significant towing, simply driving on vacations with a motorcycle in the back, I must use the "Severe" schedule and Ford will not accept a warranty issue if I have used the 10,000 mile schedule for oil changes? What would constitute "Normal" usage and qualify for this extended schedule? Seems to me that this vehicle will "make oil" regardless of driving practices and there should be no option other than the "Severe" option for servicing. I am referring to an F250 SD. Thanks.
Get the dpf delete the regen cycle is what makes the extra oil.
  #54
Old 12-10-2010, 09:45 AM
KIOTI's Avatar
KIOTI KIOTI is offline
KIOTI is starting off with a positive reputation.
Quote:
Leaking injector o-rings will also "make oil" My truck had the injectors changed in it as it was making oil. It does not make oil anymore.
I would have a oil analysis done.
  #55
Old 12-10-2010, 11:18 AM
Leaky o-rings
They have already torn down the engine. should I request they send the injectors out for testing?
Also how much fuel do think could get past the rings when the compression is @ 60psi & 150psi on two differants cylinders?
The truck was driven for approx 65miles by myself and the dealership before the engineer looked at it. The dipstick was about 2 quarts overfull.
  #56
Old 12-10-2010, 12:48 PM
Zmann's Avatar
Zmann Zmann is offline
Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.
I guess a 10k oil change is one thing.. but they should require you to check the dipstick
for proper level at a closer duration
  #57
Old 12-10-2010, 01:09 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
threads merged...
  #58
Old 12-10-2010, 01:20 PM
orng1's Avatar
orng1 orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
Most people don't check the oil. I do in all my vehicles once a week.
  #59
Old 12-10-2010, 01:23 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Quote:
Originally Posted by Krewat View Post
threads merged...
Thanks, I think that will help alot.
  #60
Old 12-10-2010, 01:34 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Even if you check the oil daily. As I understand it, because of the wire dipstick it's not always obvious that you're making oil, unless you know about the short stick method and know what you're looking for. And none of that is described in the Owner's Manual.
6.9 idi review and info F-250 XL DIESEL 4x4 4 SPEED LOCK Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 65 09-20-2016 12:02 AM
Buying a USED 6.0L bismic 6.0L Power Stroke Diesel 68 07-12-2016 11:33 PM
MY SUMMER TRIP 9400 MILES OF FUN StanleyZ 6.7L Power Stroke Diesel 15 08-29-2015 01:06 PM
Has anyone backflush oil cooler with a pond pump? Marine tactic... ShawnQ 6.0L Power Stroke Diesel 1 09-23-2014 12:36 PM
Tags
2009, 525, 64, bend, change, engine, guide, intervals, mcgregor, melted, oil, owners, pistons, powerstroke, recommeded, sienna, trail, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
