Transmission flush with extended protection
I paid the $200 to have the flush and now i have an extended coverage on my tranny.
As long as i have it flushed every 30k from now on using BG products they will pay $2000.00 toward any transmission failure i will have. I would not spend the money if it was just a commuter truck, however plowing takes a toll on tranny's and now i have extended coverage.
OK, I assume you used BG Universal Synthetic ATF in the flush. The BG web site says:
BG Universal Synthetic ATF is the superior choice to use in all passenger and commercial automatic transmissions. It meets or exceeds the performance criteria of many automatic transmission fluids including Mercedes Benz ATF, BMW, Ford Mercon® V, Mopar ATF+4™, Nissan Matic J/K, Allison C-4, Toyota Type T-IV and Toyota WS. It provides excellent protection of gears and offers superior thermal stability, anti-wear protection, outstanding oxidative stability, foam resistance and corrosion control, exceptional low temperature fluidity, and excellent shear stability to ensure a long service life.
It does not say it meets or exceeds the performance criteria for Mercon SP or Mercon LV, which is what your transmission (a 5R110W) requires.
So, good luck with that.
First off I would like to say I know the guy who owns this shop very well and have used him for 13 years and my wifes bmw as well goes there. This is not a speedy oil change place who forgets to put oil in or adds oil to the radiator. If something was to happen because of what he did he be better off to cover the cost himself then to loose us as customers. So i doubt he would screw up.
What they did was flushed the system using BG product flush machine and the quick clean cleaner. Then replaced my fluid with mercon sp and ADDED Bg transmission fluid additive. This allows me to maintain my ford warranty AND qualify for the BG product coverage. They have a tsb stating transmission fluid additive will not void any factory warranty or they will cover all costs.
There is no question that i am a doubter and i was leary about trying this product but what the hay all they do is make fluid/oil. Go to napa and ask which oil is the best...they tell me it all comes from the same place just put in different bottles with different labels.
My ford coverage is 36k or 3 years, chances are good my tranny is not going to fail in this time frame so why not do something to TRY and cover my **** down the road. If my tranny was to fail in this 36k or 3 year time frame: 1) I would not replace a bad tranny with the same tranny that failed the first time. 2) I would have to bring it to a tranny shop to have it back asap, not 1-2 weeks like the dealer would take to fix it. I would loose more than the cost of the transmission in income having my truck sit at the dealer while they twiddle their thumbs attempting to replace my tranny.
I'm planning on using all BG fluids down the road and take my chances, nothing to loose, but a chance to gain.
FYI - my receipt states Mercon SP fluid added.
Ford recommends transmission fluid change @ 30k. not just drop the pan and add new fluid. Shall we take a survey to see how many folks actually do that? According to my Ford service rep. who i just called "if your transmission fails @ 30,500 and you did not perform the proper fluid changes with legitimate records your warranty is void"
That's different
Your explaination is VERY different from your original post. As long as your use the proper fluid and follow your owner's manual for recommended change intervals, you should be OK. BTW a very small percentage of Super Duty transmissions, that are properly serviced, fail under normal use in less than 200,000 miles.
Went to dealer today to have my exhaust manifold replaced and there on the service desk was all the information about BG fluids. They said Ford uses and recommends all BG fluids. Good news for me as I was slightly concerned what Ford would have said having this done before my warranty was up.
I'm not familiar w/ BG products - is this a national brand w/ dealer shops? The $200 service is fairly reasonable particularly w/ the warranty. I think it's $150 from Ford. That said, are you sure the machine is compatiable? I think the torqshifts need a special heated machine to do a proper flush - supposedly a dealer only item but I don't know.
Today i was at the dealer and they (ford) recommend and use BG fluids. The flush machine is made by BG. Ford my local shop use the same flush machine.
I assume everything will be fine with your transmission. So I am not trying to scare you.
However, you have been duped by B&G marketing.
Ford (FMC) does not recommend a B&G transmission service. Ford (FMC) does not recommend an EGR cleaning service. Ford (FMC) does not recommend any of the gillion other B&G whiz bang things they sell. FMC has their own solution (tools/fluids) for any recommended service.
Your Ford dealer has been sold B&G equipment. Your Ford dealer can recommend any damn thing they want. That does not mean FMC recommends it.
So then what? If the vehicle fails while using dealer endorsed equipment or service who eats the cost? Bottom line is the sign above the stealership says Ford so if the FMC doesnt want dealerships doing that and doesn't condone it then why havent they stepped in and stopped it?
Ford hasn't stepped in and stopped this because Ford dealers are franchises. Ford can't dictate what they can and can't do by law. They have tried in the past and lost in court.
So my question for you - is the additive harmful enough for our tranny's that i/we should not use it?
