Headliner Removal - Ford Truck Enthusiasts Forums
Headliner Removal
Old 12-08-2010, 06:57 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Headliner Removal
I would like to get my headliner re-upholstered, and I was wondering what kind of job is it to remove it? Is it only held on by surrounding plastic interior trim or is it glued to the roof somehow? Is it just a piece of formed cardboard covered in upholstery?
Old 12-09-2010, 01:53 PM
Harfend's Avatar
Harfend Harfend is offline
Harfend is starting off with a positive reputation.
You are correct in stating that the headliner is a piece of cardboard with an upholstery cover. I repaired mine in about an hour. Very easy and an awesome improvement! I even think the truck smells better in the cab!
Removal is straight forward. I started by removing the screwed on trim pieces above the doors first, the trim above the windshield and rear window is metal and has clips that hold the trim in receiving pockets on the roof. Removal was easiest by using a putty knife and my fingers to pry out the clips. I think I also loosened the pillar trim pieces but did not have to remove them. The visors came off with the screws removed. The headliner just falls down and removal is easy, but you should be careful not to crack or break the board!
Remove the old headliner by tearing off the fabric, the old foam needs to be scraped off. Take your time and experiment using different tools to scrap off the old foam. I think I may have even used some sand paper to clean off the old foam and glue. It must be pretty clean for the new stuff to stick!
Cut your new material a bit bigger than the size of your board and use spray on adhesive according to the directions on the can. Some types of spray adhesive recommend spraying both sides of the material while others need to spray only side. That is what I used because I was afraid the glue would soak through. I sprayed the board and then I positioned the new fabric on the board and used my wife's pastry rolling pin to press out any air bubbles. (No, I did'nt tell her!)
After the new material dries you can trim it to the edge of the board because it is covered by the trim. Reinstall in your truck and enjoy the new look!
Good Luck!
HARFEND
Old 12-09-2010, 02:59 PM
Wyowanderer's Avatar
Wyowanderer Wyowanderer is offline
Wyowanderer is gaining momentum as a positive member of FTE.Wyowanderer is gaining momentum as a positive member of FTE.
Good Luck!
HARFEND
Yup. I've seen several done the same way with felt purchased at JoAnne Fabrics. I don't have a headliner in the truck, but when I do the car, this is how I'll do it. 3M Super 77 adhesive is the one I've seen used.
Old 12-09-2010, 06:25 PM
Old Hickory's Avatar
Old Hickory Old Hickory is offline
Old Hickory is gaining momentum as a positive member of FTE.Old Hickory is gaining momentum as a positive member of FTE.
Nice write up and description of the process Harfend. You have inspired me to try it on
my truck. Thanks for the information.
Old 12-10-2010, 03:31 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
Has anyone found rust in their roof once the liner was out?
Old 12-10-2010, 06:56 AM
Superred2's Avatar
Superred2 Superred2 is offline
Superred2 is starting off with a positive reputation.
I did the one in my 86 3 weekends ago and Harfend is on the money. I removed the front, rear, and side trims by pulling on them and they will pop out. I did remove the A pillar covers and the B pillar covers as well just to paint everything before I put them back so they looked nice and new.
I used a small wire brush to remove the old padding and glue and just didn't press too hard so as not to dent or tear the cardboard. I purchased the spray adhesive from Autozone and the material from Walmart. Looks pretty good!
Old 12-10-2010, 09:48 AM
85_Blue's Avatar
85_Blue 85_Blue is offline
85_Blue is starting off with a positive reputation.
Harfend... your my hero, using your girl's rolling pin!!! HAHAHAHA!!!!
Old 12-10-2010, 10:40 AM
Anafiel's Avatar
Anafiel Anafiel is offline
Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.
Yup, that's me to! Great write-up!
I'll need to remove my headliner also in order to pop out a small dent in the roof. Might as well redo the headliner while I'm at it.
Old 12-10-2010, 11:49 AM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
Is your truck a single cab or extended cab? Because if its an extended cab the only way you will get it out of your truck is if you remove either the windshield or the back window.
Old 12-10-2010, 07:08 PM
00Boss's Avatar
00Boss 00Boss is offline
00Boss is gaining momentum as a positive member of FTE.00Boss is gaining momentum as a positive member of FTE.
Quote:
I might as well do a beer window install while Im at it then right.
Old 12-10-2010, 11:21 PM
BikeMaker's Avatar
BikeMaker BikeMaker is offline
BikeMaker is starting off with a positive reputation.
I was able to remove and install mine without pulling any windows, and mines a crew cab. Not saying it was easy, but it was possible.
Old 12-11-2010, 12:34 AM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
The roof is double-walled, I'll suggest getting one of those suction cup
dent pullers.
Old 12-11-2010, 06:12 PM
mcwbyu82 mcwbyu82 is offline
mcwbyu82 is starting off with a positive reputation.
Thanks for the tips everyone. Just pulled out my sagging headliner. Thought the dome light is very interesting how two of the mounting screws complete the circuit
Removing plastic sides and headliner in cargo area? NICKSAN 1968-2013 Full Size Vans 3 10-20-2015 11:20 PM
Headliner Removal KellerMAC 1999 - 2003 7.3L Power Stroke Diesel 13 10-16-2015 07:47 PM
Dropping/remove the headliner easy way? The_Punisher Excursion - King of SUVs 2 04-14-2012 11:29 PM
f350 Headliner adamss 1999 to 2016 Super Duty 6 04-19-2009 01:41 AM
Removing headliner on a Crew cab? bigtimebubba 1999 - 2003 7.3L Power Stroke Diesel 10 03-27-2009 04:19 PM
Tags
04, 1985, 2008, 2009, 2010, cab, dent, extended, f150, f250, ford, head, headliner, liner, removal, remove, removed, removing, small, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
