97 f-150 timing
Old 12-08-2010, 04:47 PM
mikescnw's Avatar
mikescnw
mikescnw is offline
97 f-150 timing
working on a 97 f-150 two wheel drive with a 4.2 v6 poor fuel economy like 12 mpg. I pluged in my scan tool and was watching the total ignition advance while driving down the road it was reading a total of 26 degrees an average of about 8 degrees and a low of 1 degree. I called ford they had no idea what the total should be. I know that most GM vehicles run a total of 38 to 42. ANY IDEAS??????
Old 12-08-2010, 05:52 PM
paker's Avatar
paker
paker is offline
I have had the same problem. Same year/engine. Recently found evap return line busted and repaired. Don't know yet if it was the cause.
Old 12-08-2010, 06:21 PM
mikescnw's Avatar
mikescnw
mikescnw is offline
thanks, dont know if that would effect timing either, might be an ecm problem I think 97 was the first year for the 4.2, havent heard of any one else that has the same problem.
Old 12-09-2010, 02:30 PM
paker's Avatar
paker
paker is offline
I remember reading somewhere 8 deg is about right. But I am not a mechanic.
By the way, I meant very poor mileage by "the same problem." I haven't measured timing on this vehicle.
Old 12-09-2010, 05:58 PM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
What does ignition advance have to do with anything? The computer will adjust timing as needed. So long as the timing marks are aligned properly and the cam and crank sensors are adjusted correctly, there is no need to mess with anything else.
Just give the truck a tune up with OEM spec parts and see if that doesn't solve your problem.
What is the Long Term Fuel Trim on each bank, that is an important value that can actually help you.
Old 01-03-2011, 08:49 PM
paker's Avatar
paker
paker is offline
Is long term fuel trim measured while idling or cruising? Which one would you need?
scotts630
1997 - 2003 F150
08-10-2021 09:55 AM
skidooosl
2004 - 2008 F150
11-11-2015 03:15 PM
Spoonman75
09-07-2015 11:34 AM
heavymetaljim
1997 - 2003 F150
03-06-2014 07:26 AM
LARIAT 85
02-23-2014 03:29 PM
Quick Reply: 97 f-150 timing
