1997 7.3 oil leak - Ford Truck Enthusiasts Forums
1997 7.3 oil leak
Old 12-08-2010, 02:10 PM
1a2a3a 1a2a3a is offline
1a2a3a is starting off with a positive reputation.
1997 7.3 oil leak
my truck is leaking oil bad! i know for a fact the rear main is leaking. but it is also leaking from the front too and its not the crank seal. i already checked the HPOP reservoir and not that either. can anyone tell me some more places it can leak from?
Old 12-08-2010, 02:21 PM
Robbgt's Avatar
Robbgt Robbgt is online now
Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.
Mine was leaking from one of the "Blank" plugs on the HP oil galley. I replaced it and put an HPX line in, but you could just tighten/ replace O-ring (I think they're O-ringed)
just another place to look... good luck
Robb
Old 12-08-2010, 02:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Exclamation
Also check the big bolts o-ringed at the end (front and back) of the galleys or the valve cover gasket
Old 12-08-2010, 08:37 PM
machmedic machmedic is offline
machmedic is starting off with a positive reputation.
Check your turbo pedistal and under the HPOP. The plugs on the HPOP have been known to leak, I've been there and done that. Good luck.
Old 12-09-2010, 12:57 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Robb
Robb, they are O ringed but it doesn't sound like 1a2a3a's problem.
Old 12-09-2010, 06:40 AM
Robbgt's Avatar
Quote:
Ah, I guess the oil would run into the valley and to the back of the engine... he said the issue was the front. Thanks for catching that
Old 12-09-2010, 12:39 PM
maybe since im having such bad luck with this diesel it would be better if i jerked it out and dropped a 351 cleveland in. lol
Old 12-09-2010, 09:36 PM
Oh, no no. Just step back and take a break. Get the PSD running and you'll be a lot happier with it then a 351. Of course, I should just mind my own business!! LOL
Old 12-09-2010, 10:18 PM
jg96powerstroker's Avatar
jg96powerstroker jg96powerstroker is offline
jg96powerstroker is starting off with a positive reputation.
Quote:
hey men myn is doing the same thing, always has a small oil puddle in the center front, had coolient in it to day, found out its my oil cooler leaking and oil is running down front crossmimber on to frount end and makes it look like its in the center of the truck, look at the oil cooler on drivers side good luck man
Old 12-10-2010, 10:26 AM
mine looks like its leaking on the passenger side somewhere. the driver side of the motor is pretty much dry buy the passenger side is soaked. and yes i do have a crap load of oil dripping off the crossmember but the oil cooler is dry. do you know of anything on the passenger side? the valley on top is completely dry and same with HPOP lines and plugs.
Old 12-10-2010, 10:47 AM
It might be coming out of where the oil dipstick goes thru the oil pan. That's always a common leak area.
Old 12-10-2010, 04:43 PM
yeah thats true, 10 cent fix from parts store, just take the dipstick tude out and with you and you can get an o ring that will work, it leaks just enough you look past it
Oil Leak IBleedOvalBlue 1999 - 2003 7.3L Power Stroke Diesel 21 06-10-2016 01:18 PM
Differential oil leak at wheel hub F1Hunter 1961 - 1966 F-100 & Larger F-Series Trucks 19 11-28-2015 12:27 PM
2006 6.0 L Diesel engine oil leak Gary A. 6.0L Power Stroke Diesel 46 07-20-2014 10:19 PM
1995 7.3 is leaking oil bad please help!!!!!! jasen 1994.5 - 1997 7.3L Power Stroke Diesel 19 06-19-2014 09:59 PM
Oil Leak Question 88 F250 7.3L LFDavidson Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 11-09-2011 05:43 PM
Tags
1997, 73, check, cooler, diesel, drivers, engine, ford, leak, leaks, oil, passenger, places, powerstroke, side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
