Power steering leak... sensor on high pressure line? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-08-2010, 01:17 PM
staysbroken staysbroken is offline
staysbroken is starting off with a positive reputation.
I think I've tracked my power steering leak to some type of sensor on the pressure line, close to where it connects to the steering box:
I assume this is a pressure sensor? I got no CEL or anything like that when the fluid had leaked down to the level that the pump started whining pretty badly though. As far as I can tell by looking at pictures, the parts store replacement pressure lines do not have this sensor, or any provision to connect a sensor to it: Advance Auto Parts: Power Steering Pressure Hose by Powercraft - Part 71878
Anyone run into this issue before? I may just put a replacement line on there and leave the sensor plug hanging and see what happens...
Thanks!
Old 12-08-2010, 05:32 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
The sensor is a pressure monitor that will kick up the idle speed when turning sharply at idle, like parking. It is only on 2.3L, as the V-6's have enough torque at idle to run the p/s pump. If the sensor is leaking, but not the line itself, try putting a plug in it to see if the leak goes away. You might have to kick the throttle a little when parking or turning sharply while at idle.
Old 12-09-2010, 01:25 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Try the Ford OEM version. yeah it cost more but you know it's going to work or you'll be refunded and re-parted.
http://www.trademotion.com/partlocat...layCatalogid=0
Old 12-09-2010, 08:08 AM
Would either of you happen to know if the OEM hose and the sensor are one piece (for $60, I would hope so...), or if the sensor is a separate unit that attaches like an oil pressure sender?
Thanks
Old 12-24-2010, 01:54 AM
On my 1990 Bronco the fitting was on the hose but I had to screw the sensor back in.
Old 12-24-2010, 02:09 AM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
The sensor can be purchased separately. Check LMC truck. You may want to call them to see if the hose for your truck has the connector for the sensor. I am assuming you have the 2.3 L engine and your truck is somewhere in the 1990 to 1997 range.
It would help if you included info such as year, engine and related information in your signature.
Old 12-24-2010, 09:28 AM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
that pressure switch is also one of the parameters for the air conditioner, along with
the wide open throttle cutout.
if that detects too much pressure the ecu will turn off the a/c compressor momentarily.
this will reduce load on the engine so that it does not stall,, i.e. parking lots.
at least thats what the service manual says.
sure would be alot nicer if that switch was actually a nanny that tells you if you run out of fluid so that you do not fry your power steering system.
Old 01-07-2011, 05:40 PM
It's a '97 2.3, as is indicated in my signature.
I picked up the parts store replacement hose for about $20. Evidently it does have a threaded hole for the sensor to be screwed in, but it came with a little plug for applications that don't use the sensor. I think it may even be the sensor itself that's leaking, and not the hose, but I haven't yet been able to get it off. Nor have I been able to unhook the old hose from the steering box.
I've been trying to first unhook what I assume to be a return line from the steering box in hopes that doing so will make it easier to get a wrench on the pressure line. I can't seem to put enough torque on the return line wedged down between the p/s pump and wheel well though, so I think I'll try and find a longer set of box end wrenches and try again. I can see the fitting by looking above the tire through the wheel well, but the brake line is in the way of getting a wrench in there. Any other ideas?
Thanks!
Old 01-12-2011, 11:38 AM
Well, I got a set of crow's foot wrenches, and still no luck getting the hose off the steering box. Something is preventing the wrench from grabbing the whole width of the fitting, and it just slips off. I bet it would be a lot easier if I pulled off the p/s pump itself first to get better access, but that looks to be a whole project in and of itself, including pulling off the pulley. Until I find the motivation to tackle that, I'll just live with it leaking. Sorry, Al Gore
Power Steering High Pressure Line ? gman97005 1968-2013 Full Size Vans 6 10-23-2016 09:25 PM
Saginaw conversion HP line wrdabney 1987 - 1996 F150 & Larger F-Series Trucks 2 05-18-2016 05:04 PM
Power Steering Flush/Rebuild DattMavis 1987 - 1996 F150 & Larger F-Series Trucks 1 01-19-2016 06:05 PM
Power steering hose question. 1976 F250 2wd AK FORD GUY 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-08-2011 07:49 PM
Highboy power steering hoses Blown 331 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-26-2010 08:19 PM
Tags
05, 06, 60, f150, ford, high, line, power, powerstroke, pressure, ranger, replacement, steering, sterring, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
