You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
2011 6.2L Ford F 350 , DRW, 4:30 limited slip rear end, 17" wheels ,4 x 4
Towing a 5th wheel trailer Approximate weight 15,000 lbs +/-.
Traveled from Middle Tennessee and San Antonio Texas. in the past week.
These are the stats from the drive.
25.49 hours,
171.9 gallons,
1215 miles.
Average 53 mph,
7.1 miles per gallon
As a convert from a 6.0L and 6.4L diesel this trip has been an adjustment.. When you drive with your senses as I do, the difference between the two is quite an adjustment.
I went with gas because of the lack of mechanics for the diesels. and the frustration with trip interruptions due to failures. We travel 6 months a year all over the country. Also the sight of lifting the cab off to do engine work never did give me comfort down the road. I simply got tired of the added expense and break downs over the past 5 years.
I agree with all previous comments regarding the six speed transmission shift points. I have used the manual, tow haul and normal over the trip. and none is quite satisfactory. It jumps to lower gears to quick, and stays in gear to long on acceleration under load. Some adjustment would be appreciated.
I hope this is helpful and is useful to all.
__________________ Rob 2007 F-250 6.0 CC SB 4x4 Black Sport FX4 20inBlackBMF Novakane 8 W/ Toyo M/T 33x12.50x20 Stock Motor 2004 F-250 6.0 CC SB 4x4 Black Sport FX4 Sold-She was problem free.
This is one of the things I have been looking for. Your 5er is right at 3,000 to 4,000# heavier than mine. I'm hoping to get right at 8 to 9 towing at 60 to 65 with the 4.30 rear.
What speed where you traveling? Your average MPH is really good for that many miles. You must have stayed in the driver seat pretty straight. I always have to stop every 1 1/2 to 2 hours for wife to go tinkle. Anytime you have to keep stopping it really cuts into average MPH. When I'm out in our little Miata I can do much better MPH but I go a lot faster in it than in the truck towing.
We have a 10k 5ver and get 9 to 9.5 max on flat hwy 60-65...and we have 4.30 gears in our truck. I dont see any reason why you could not get 8-9 towing unless your in some extreme mountains.
The difference in this leg (900 miles) was the lack of a head wind for most of the trip. There were a couple of climbs to 4800 ft +/-. All in all I was pleased.
The truck handles as well as any I've had. I just have to adjust to the higher RPM's of a gas engine.
Will stay in the Southwest till April then back to TN.
Will report on return trip
