Got these off of ebay, just put them in. Kinda wish the crome matched the grill more . Putting them in was easy, here's a few pics, will get a night shot in later
Looks good. I wonder if the projectors are much better than the standard clears like mine...
Personally I like the look of mine better, but those look good too.
Im with Evan, I also like more mine, but it should be because they look too much margin black and dont crome match the grill as it should (as you mentioned above). I think the best look of yours will be in the night. We will see your night pic. Maybe will look like an Audi
Its easy to adjust the proyectors?
Once I see the night shot I will be able to say which I like more. The black trim might look good on my truck but not sure. They would look sweet if I were to black out my grill.
I'm not sure yet about the adjustment, they need to be angled up more but might be good where there at after my RSK is installed. They're a standard bulb for now, soon will be the HID's. I like them so far though. They fit nicely, they mounted on the two bottom assemblu bolts and the two top headlight adjustment bolts, no problems except a pain to remove the old ones.
here's a night shot
There's 3 LED's on the outside and the bulb at the bottom is supposed to be the amber bulb so I need to change that as well.
well that housing you have is definitely the best setup for HID's, it will direct the light where the light is supposed to go. But i couldnt put a set on my truck, i like my all clears to much hah
Could post a pictures of the headlights at night but a little farther back from the truck. Also post a pic of the them shining out at night. I would like to see the pattern they throw.
