1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trailer running lights
Old 12-07-2010, 04:18 PM
John Puig's Avatar
John Puig
John Puig is offline
Need help in locating the fuse that would control my trailer running lights. My trailer brake & turn signal lights work. When I connect my trailer to other trucks the running lights work. I assume this means I have a blown fuse that controls my trailers running lights as I've checked all wiring. Can anyone point me to the correct fuse. The truck is an 2008 F350 diesel that has two fuse boxes--one located inside the passenger side and the other under the hood.
Old 12-07-2010, 04:30 PM
bpounds's Avatar
bpounds
bpounds is offline
Did you check your owners manual? They are identified in the manual. Also, you not only have fuses, but there are relays for all the trailer outputs.
Old 12-07-2010, 04:31 PM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
I blew that fuse once too, i believe i found it in the manual.
Old 12-07-2010, 04:39 PM
bpounds's Avatar
bpounds
bpounds is offline
Looks like fuse #42 (30A) and relay #55.
Under the hood.
Old 12-07-2010, 04:41 PM
John Puig's Avatar
John Puig
I've looked in the manuel-- but it was no help although i did check various fuses but all were ok
Old 12-07-2010, 04:42 PM
John Puig's Avatar
John Puig
Check that but no help-- I did check out various fuses but all were ok
Old 12-07-2010, 04:44 PM
John Puig's Avatar
John Puig
Under the hood.
I did not check the under the hood ones as they are difficult to access-- but I guess I'll try
Old 12-07-2010, 04:45 PM
bpounds's Avatar
bpounds
bpounds is offline
You didn't think it would be easy, did ya?
All the trailer stuff is under the hood, I believe.
Old 12-07-2010, 04:46 PM
bpounds's Avatar
bpounds
bpounds is offline
BTW, in your manual, look under Roadside Emergencies. That's where they list the fuses.
Old 12-07-2010, 05:20 PM
John Puig's Avatar
John Puig
Well you oh son of a gun-- Thanks-- Found how to get to fuse #42 & sure enough it was blown-- changed it out and now my running lights work-- Thanks so much for your help!!!!!
janjan1
07-10-2017 04:20 PM
Hybris
2009 - 2014 F150
01-03-2016 07:32 PM
silentrunning
02-24-2012 06:20 AM
Deerslayinrenek
06-25-2010 03:58 PM
birchy
1997-2006 Expedition & Navigator
07-16-2009 09:16 AM
Quick Reply: Trailer running lights
