Looking at buying a new ranger but I am wondering what is the largest tire size that will fit on one without rubbing. A 2011 4x4. Going to be leasing it so not doing suspension mods and using the stock wheels. Thanks.
The stock largest tire accounts for fully loaded vehicle, really rough road, sharp turns, steep inclines, etc. If you never intend to do any on these things, ask your local tire store what they recommend. Store your stock tires as they will have to be put back on when you turn in the lease vehicle.
You should leave the stock tires on, because if you do plan to go off road, it will cause the larger tires to rub. You could probably get same size tires but with a different tread.
