92' 4.9 fuel system problems - Ford Truck Enthusiasts Forums
Old 12-07-2010, 12:40 PM
Dan92 Dan92 is offline
Dan92 is starting off with a positive reputation.
my truck keeps wanting to bog down when i hit the gas and it also has a large lack of power. ive been told that it could be my fuel pressure regulator, my fuel pump or my furl filter clogged. i changed my fuel filter and it didnt help. if it was my pump going out on me wouldnt it have gone out by now? its been doing this for 2 weeks and before it started hesitating it would have slow starts where i would have to turn on and off the key a few times to pressurize the fuel system. now it does both.
Old 12-07-2010, 01:26 PM
bl2009 bl2009 is offline
bl2009 is starting off with a positive reputation.
I've went thru similar problems on my '93 f150 and it turned out to be the coil. My truck goes thru coils in maybe 4 yrs. They just don't seem to last. bjr23
Old 12-07-2010, 02:18 PM
could the coil cause the fuel system to de-pressurize though?
Old 12-07-2010, 02:31 PM
87 XLT 87 XLT is online now
87 XLT is gaining momentum as a positive member of FTE.
Checking fuel pressure is very simple. If you have a Harbor Freight handy, they will sell you the gauge for 20 bucks. Screw it onto the Schraeder valve & post your results.
Old 12-07-2010, 02:51 PM
okay ill check into getting the gauge
Old 12-09-2010, 09:03 AM
I just went ahead and bought a new fuel pressure regulator, i got it for 30 bucks off of ebay brand new. by the time i buy the 20 dollar gauge it just wasnt going to be worth it. thanks though
Old 12-09-2010, 09:23 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
I dough the fuel pressure regulator is bad unless you had fuel in the vacuum line to it.
You still need the gauge to see if anything is wrong with the fuel system.
Most of the time this problem is the TPS and you need to check it with a analog VOM.
But the TPS may not show up when you run the codes.
What you need to do first is see if you have any hard codes or any codes stored in CM.
If you do not know how to do this go to this link:
http://www.fordfuelinjection.com/?p=13
Old 12-09-2010, 12:19 PM
well i did pull the vaccum line off of it and it had a really strong gas smell to it. i dont know if that would mean anything
Old 12-09-2010, 12:24 PM
Where is the TPS located on my truck?
Old 12-09-2010, 12:56 PM
subford's Avatar
Gas in the vacuum line to the FPR means you have a bad FPR.
The TPS mounted on the throttle body.
For more information on the TPS go to this link:
Ford Fuel Injection Throttle Position Sensor (TPS)
Old 12-09-2010, 01:04 PM
Thanks a lot, i just got my engine rebuilt and this happend. ill let you know how it works out.
Old 07-12-2014, 07:22 PM
Tomcatervf102 Tomcatervf102 is offline
Tomcatervf102 is starting off with a positive reputation.
Question, will the Aft Tank(18.2 Gal) pump Work in the 19.0 Gal. tank?
1993 f150 4.9 2wd jtingle92 1987 - 1996 F150 & Larger F-Series Trucks 4 08-28-2015 06:27 PM
92 bronco 5.0l - New fuel system but won't start 75_92_95 1978 - 1996 Big Bronco 13 07-22-2015 09:47 AM
2-Barrel Fuel System ? -- F250 1962 jawroper 1961 - 1966 F-100 & Larger F-Series Trucks 14 05-26-2015 05:29 PM
98 2.5 fuel pressure down to 40psi 1998Ranger25L153CID Ranger & B-Series 4 03-22-2015 05:55 PM
91 was now not running Ifdot 1987 - 1996 F150 & Larger F-Series Trucks 7 12-01-2014 06:27 PM
Tags
49, 92, 96, f150, ford, fuel, pressure, problems, regulator, symptoms, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
