You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Been using my brother's F 250 running on Bio-diesel (100%) for about a month since I came to Atlanta. Yesterday and today the temp was low approx 33. Had difficulties starting both days, once started no problem runing or restarting
Glow plug seems inadequate to heat the fuel.
Is there a heating coil that can be installed to help when the weather is so cold?
Elton
PS.
Batteries are new.
Reason: Addtional info
Welcome to FTE! At those temps you need to blend down to about B80 or B60 to avoid cold start problems. B60 is 60% bio and 40% D2, and B80 is 80% bio and 20% D2. B100 gels at different temps depending on the original feed stock.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Block heaters are good, but still need to make sure your mix isn't gelling. Add a couple gallons of straight Diesel, or an additive. When I got caught by surprise earlier this winter I used Diesel Kleen... Bio's gell point can be in the 40's, depending on the oil that it came from and its quality...
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
I run B100 in the summer but slack off in the winter. To blend you need to put the diesel in after (bio will sink when added).
I found it 'gels' around freezing (mine is made from waste cooking oil) and according to a guy I talked to at Howes, no 'anti-gel' additive works effectively on Bio.
It may be worthwhile to change the filter....
__________________
2001 SD 7.3L PSD S-Crew Long Bed
Did not improve much with the blend. However some one told me that here is a block heater available, how effective are they?
Like everyone else has said, the block heater won't help with the fuel gelling. But to answer your question about the block heater...what year is it? I know all of the 7.3L & 6.0L were built with them, but only up to the '04 model year did all of them come with a cord out the front.
I don't spend much time outside of the 6.0L forum...so I have no clue about the 6.4L or the 6.7L; I did look in the 6.4L tech folder...but there isn't anything about the block heater listed in there. I'll echo what Don said, welcome to FTE.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
They have a B-100 product but say it is only good for soy based BD
Used it down to about 20deg on my home brew but i have not bought any more just went back to pump diesel in the winter months cause i was chicken to try it in any colder weather.
If you are using a good quality mass produced bio that is not fat based you should not have starting issues @ 33 deg you might want to check all glow plugs for opperation when I did mine last fall only 3 of 8 were actually working. Started ok down to about 40deg but lower than that it was a bear......
__________________ Light travels faster than sound. That's why some people appear bright until you hear them speak.
2007 F-350 Lariat CC,LB,SRW,2x4, Brite Box, High Idle sw, No Kitty & Straight Pipe, Blue spring & Sinister coolant filter & Fumoto.
