Door Ajar Switch Wire Color - Ford Truck Enthusiasts Forums
Old 12-07-2010, 01:56 AM
Shadow351's Avatar
Shadow351 Shadow351 is offline
Shadow351 is starting off with a positive reputation.
Hello, I am in the process of installing a security system in my 97 F150 after someone broke in (by Drilling out the passenger side door lock cylinder) and stole my stereo, destroying both door lock cylinders, both door handles, dash trim ring and the 12Volt outlet door. Anyways, the alarm needs an input from the door ajar switches but I cant seem to find them in my manual's wiring diagrams. I know they are part of the door latch, that I need to tap into both (isolating each with a diode), and that they are ground-out switches but that's all I have found out so far, Anybody have more information for me such as the wire colors etc.? thanx in advance.
-Brad
P.S. Jimmi Jammers stop thieves from punching a lock but not from drilling one.
Old 12-07-2010, 06:12 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Driver's door - BK/YEL
Pass door - BK/PK
Wire is grounded by latch switch when latch is closed.
Old 12-10-2010, 12:19 AM
Shadow351's Avatar
they ground out when the latch is closed (door latched)? Thats different, I hope its not an issue. I hope I can make this alarm work, it was expensive. thanx for the info
-brad
Old 01-15-2011, 12:30 PM
Shadow351's Avatar
Ok so i finally got a chance to work on this again and upon testing with a volt meter this is what i found. When the door is open the BLK/Yel wire is not grounded or hot, it is just floating, like 0.1-0.2 volts. When the door is closed it goes to 9.8 volts? this is wierd is this right or should it be 12V when the door is closed or is there an issue with my door switches? thanks
-Brad
Swap door ajar sensor polarity? noober0x 1999 to 2016 Super Duty 2 08-07-2016 04:54 PM
Door Ajar/Interior light switch Absolute 1999 - 2003 7.3L Power Stroke Diesel 4 01-25-2016 05:20 PM
Door AJAR Switch Replacement on 2002 XLT w/Photos borland Explorer, Sport Trac, Mountaineer & Aviator 34 01-07-2015 11:15 PM
New to me 2000 Ranger 1great40 Ranger & B-Series 4 01-04-2015 06:20 PM
Door Switches Doing a Crazy Thing!! JHadds Excursion - King of SUVs 3 11-18-2011 02:00 PM
Tags
04, 07, 150, 2004, ajar, color, diagram, door, f150, f250, ford, switch, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
