P0299 low turbo boost ?
A few weeks ago I had this code appear with a CEL. It came on while at a gas station truck was sputtering just off idle . It ran fine on the road driving so I cleared the code all has been fine till tonight while plowing a parking lot It appeared again with the odd idle stumble that clears up with stabbing the throttle,but everytime I came to a stop and went from forward to reverse it stumbled almost like it wanted to stall out on me.So my question is could it be the turbo causing the just off idle stumble
Leaving the parking lot it ran fine all the way home .I will also add that plowing this lot is very low speed driving due to cars and other obsticles so not seeing much for rpm over 1500.
The motor uses a default strategy and, of course, you will have a constant CEL. You will also gain a P0470 because of unplugging the sensor. I wouldn't advise driving it long term with the sensor uplugged. It's there for a reason. Be sure and remove the metal tube and check it for obstructions.
MN_Andy
07-24-2017 05:20 AM
smooth2904
Modular V8 (4.6L, 5.4L)
12-30-2016 06:38 PM
HawaiianPSD
15
06-06-2016 12:55 PM
hoss khaos
13
02-21-2016 06:35 PM
