IFS axle center u-joint
It may be quicker to do it while it's still in the truck, just going to be kinda a PITA. If you do pull the beams then you might as well put in polyurethane pivot bushings and radius arm bushings along with checking the ball joints and spindle bearings b/c your going to have all that off the truck
I can tell you from experience that IF you know how to handle the hub assemblies then it will be much easier to remove the chunk from the truck. It sucks too but not nearly as much as I imagine trying to swap that joint on the rig would.
Remove wheels, pull both hub assemblies, pull both spindles, remove the driver's side axle stub, unclamp boot near the joint you are speaking of and remove passenger side axle stub, let the driver's side tie rod end loose and tie the link up out of the way, jack up frame to unload springs, loosen DRIVER'S side u-bolts, remove bolt @ pivot point of IFS, unclip the vent line from the frame, and voila you have a free third member. You don't have to remove the passenger side axle stub housing. Oh and unbolt the front end of your front driveshaft and hang up out of the way. Sounds like a lot but it is mostly wrenching and I bet it would be about the same time frame as just battling that joint. Plus you could do the other joints if need be on the front axle, tie rods, ***** joints, the pivot bushing, hub bearings/seal, diff fluid, etc, etc if needed while it's apart.
Just another thought...
Are you talking about an axle u joint or a pivot bushing? the u joints are easy. Pull the rotor, caliper and spindle. There is a real neat adapter for a slide hammer that screws on to the spindle that you can get at napa to make that part easier. Then just pull the axle. I don't understand what everyone is talking about with pulling the carrier and unbolting the axle and everything.
For the pivot bushings, just put a jack under the frame behind the tire, pull 1 bolt out of the pivot bushing and lower the jack a bit. That end of the arm will come right out then if you have a real air chisel, go to town on the bushing. If not, then a torch of BFH will work. YOu don't have to pull the whole thing apart for any repair on an IFS.
on
But like I said before there is no reason to pull the axles or axle housings. you can do the u-joint without it. It would be better to pay some one to torch it and press it back in then it would be to tear it all apart.
SUPERDUTY_08
1999 to 2016 Super Duty
06-28-2016 05:24 PM
rkeith213
03-06-2015 01:54 PM
