What size drop for hitch for my truck? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-06-2010, 03:54 PM
Future_LEO's Avatar
Future_LEO Future_LEO is offline
Future_LEO is starting off with a positive reputation.
I am moving this weekend and renting a U-Haul 6x12 trailer. Should be a quick move.
My truck is lifted 4" and has 37" tires. Was thinking 5 1/4" drop hitch? Or would I need more/less.
Thanks
Old 12-06-2010, 04:00 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
It depends on the trailer and how much weight you put in it. I don't think 5 1/4" will be enough drop. With the tandem axle utility trailer I pull I usually use a 4" drop however if the load is more front heavy I have a 2" also. Sometime I'm going to make a 3" drop. My 04' 250 is stock height with 33" tires on it. Drops are not that expensive so I always have more than 1 (with ball) and a pintle. The trailer should take a 2" ball.
Old 12-06-2010, 07:01 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
move
if it's a short move it wont make.
Old 12-06-2010, 07:05 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Yeah, the hitch height of trailers can vary quite a bit. I suspect U-Hauls tend to be on the lowish side as they are designed to be compatable with what the typical renter would be using. SUV's, half ton 2WDs, or even large cars), so I predict you'll need closer to 8".
Old 12-06-2010, 08:08 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
I bought a Buyers Products 3-ball heigh adjustable hitch about 5 years ago. Best hitch investment I've made. I have all ***** I need and I can adjust the height to whatever I need.
I can't stand it when I see some numbnutt pulling a trailer where the truck and trailer make a V. Nor can I stant the ones that look like ^. Adjust the hitch to pull the trailer level - thats how its supposed to be.
The only variation to this I could understand is if the angle of the ramps on a trailer is too sharp between the top of the ramp(s) and the bed of the trailer for what you are loading to clear. If it was my rig I would just drop the jack and crank it back up when I was ready to roll. More time/effort, but to me its worth it.
Those UHauls won't have a whole lot of toung weight for a SD. When you load it I would have the hitch adjusted to where the angle of the toung is barely climbing towards the truck, if any.
Also - a BIG tip - don't load it light on the toung!!! Those things are notorious for fishtailing when not loaded properly. I've done it. Make sure the majority of the weight you're loading is in the front.
Old 12-07-2010, 03:06 AM
Future_LEO's Avatar
Thanks for the input guys. I may swing by the U-haul place I'm getting it and take some measurements and figure it out that way. I really want an adjustable one, but they are like $150+. Money is tight with the move this weekend and in 2 weeks making a trip back home to Ohio for the Holidays. If I can come up with the funds, then I might snag an adjustable one...we'll see.
Help with drop hitch P4IN COMM4NDO Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 13 01-02-2017 12:16 PM
Trailer hitch Height wb6anp 2017 Super Duty 37 10-07-2016 03:22 PM
1965 f100 Fords & Whalers 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-28-2016 06:27 AM
Proper Hitch USCG_PA Excursion - King of SUVs 41 06-06-2015 02:18 PM
How big of a drop hitch do you use on your SuperDuty? TxFireman1972 1999 to 2016 Super Duty 14 08-01-2010 07:46 PM
Tags
2007, 2008, 6x12, drop, f150, f150stock, f250, f350, ford, height, hitch, size, stock, trailer, uhaul
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
