8 lug 15 wheels on a highboy - Ford Truck Enthusiasts Forums
Old 12-06-2010, 03:46 PM
ozzy460's Avatar
ozzy460 ozzy460 is offline
ozzy460 is gaining momentum as a positive member of FTE.
ok how hard would it b to get 8 lug 15s to clear on a 77 f250 highboy w disk brakes? is there alot of grinding? is it safe? im so sick of 16.5 wheels!!
Old 12-06-2010, 03:49 PM
cabloom300's Avatar
cabloom300 cabloom300 is offline
cabloom300 is starting off with a positive reputation.
I have them on. You need to get 2.75 in backspacing for it to work and i still had to grind about 1/8 in off a couple places on the caliper. Also having that little backspacing they stick out quite a bit just FYI
Old 12-06-2010, 03:56 PM
ozzy460's Avatar
they the ones in ur gallery? they dont stick out bad at all.
Old 12-06-2010, 08:39 PM
cabloom300's Avatar
Yea they are. I can get you a pic from the front tomorrow where they stick out more. I dont think they stick out to bad but some people dont like the look. Basically they will stick out about 1.5 inch more than your average tire/wheel with a 12.5 wide tire on it.
Old 12-06-2010, 08:46 PM
piperig78 piperig78 is offline
piperig78 is starting off with a positive reputation.
I have 15" Diamond racing rims with 2" of back spacing on my 78 F-250 4x4 front is dana 60 with disc, fit with no grinding.
Old 12-06-2010, 09:12 PM
cabloom300's Avatar
Quote:
I agree if you went with like a 2.5 inch backspacing you probably wouldnt have to grind at all but the tire would really stick out. I wanted to have it in as far as i could without to much work to make it fit.
Old 12-07-2010, 07:05 AM
ozzy460's Avatar
yea id like a pic. i got a set of 36in iroks i want to use. their 13.5 wide.
Old 12-07-2010, 09:53 AM
cabloom300's Avatar
I cant get the other ones to load right now or i would post more.
Old 12-07-2010, 09:59 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
You could always go with 16's.
Old 12-07-2010, 10:10 AM
blackkawi400's Avatar
blackkawi400 blackkawi400 is offline
blackkawi400 is gaining momentum as a positive member of FTE.
I'm still really confused on what the issue with 16.5's is.
Old 12-07-2010, 10:28 AM
78_f150 78_f150 is offline
78_f150 is starting off with a positive reputation.
Quote:
first you cant buy many tires for a 16.5 any more. second 16.5 wheels have no saftey bead. so when running low air psi, the tire can fall off the bead, and a leak of any sort and the tire goes low, it can just fall off. they were not the safest wheel design.
I am using 8 lug 15s on my dana 60s and the front i had to grind the calipers down. My wheels dont have much backspace, so i cut a decent amount off the calipers. its close now but no rubbing. I happen to have stumbled on the wheels in my shop. At first i thought they were 16s but tried to put a tire on and they ended up being 15s.
Old 12-07-2010, 10:39 AM
I just looked up several tire manufacturers and there were plenty of 16.5 tires. I've been hearing 16.5 tires were going to stop being made for years and yet they're still here....
I think you may be thinking of the old 16.5 split rims when talking about the bead falling off. And some 16.5's have a safety bead.
And if the OP is going to run less than 15psi he needs to invest in a set of beadlocks anyway.
Old 12-07-2010, 10:52 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
IMO
I'm with what blown 331 said, go with 16's no grinding and that's a common size tire these days. 8 lug 15's might get $$, that's not a common size/lug count setup IMO.
Also with 16"s your option's should be off the scale as far as rim choices. See attached pic.
You can always get Goodyear Wrangler MT II's old military HUMVEE takeoffs in a bias ply 36X12.50X16.5 can re-groove to fit your needs or a radial in a 37X12.50X16.5.
All day long for cheap, I run them on ol Red, cause I have a ton of 16.5 rims Aluminum mags/spokes/hurricanes and old style white spokes. Dodge 3/4 16"s will fit too.
You can always get some bead-locks for your 16.5's and never worry about it again.
MRW Bead-lock Wheels
Old 01-06-2011, 06:28 AM
JJs99XJ JJs99XJ is offline
JJs99XJ is starting off with a positive reputation.
single pistons calipers?
Quote:
Do you have single piston calipers or dual. And can you grind duals to fit 2.75 backspacing?
Old 01-06-2011, 07:36 AM
cabloom300's Avatar
I have dual piston, i think all highboys did. They might clear on single piston im not sure.
2.5 ton rockwell and oldstyle 8 lug parkerparkerm Clutch, Transmission, Differential, Axle & Transfer Case 0 03-09-2013 08:21 PM
Rims kilich 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-20-2011 10:35 PM
What year did 8 lugs change MADFord4X4 1973 - 1979 F-100 & Larger F-Series Trucks 15 09-07-2011 04:55 PM
8 lug or 10 lug Wheels zxkeller 1999 to 2016 Super Duty 9 12-22-2010 08:35 PM
1979 F-250 Wheel Lug Bolt Pattern Comanche1Star 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-05-2010 01:11 PM
Tags
15, 1977, 77, bolt, boy, f250, fit, ford, high, highboy, inch, lug, military, pattern, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
