IP or Head Bolts? - Ford Truck Enthusiasts Forums
IP or Head Bolts?
Old 12-06-2010, 03:44 PM
DieselScoff's Avatar
DieselScoff DieselScoff is offline
DieselScoff is starting off with a positive reputation.
Smile IP or Head Bolts?
I am driving a pre 92.5 7.3idi just replaced all the injectors. But I have to start in with ether all the time even when below 40 degrees. I am going to put a new injector pump on and head bolts instead of head studs due to cost right now, might change my mind later. I am wondering who thinks would be the culprit the low compression or a softy IP that is causing the starting issue, pump is turned up 1.5 flats. Total cost on parts without shipping is around $700 for IP pump, head bolts and Gasket set. Thank you for your thoughts.
Old 12-06-2010, 03:50 PM
michbol's Avatar
michbol michbol is offline
michbol is starting off with a positive reputation.
Have you checked your glow plugs? What does your "Wait to start" light do? Can you hear the glowplug relay cycle? Did you put a new return line kit on when you did your injectors? You could easily have an air intrusion problem as well.
You definitely need to be checking GP system before you start in with other issues.
Old 12-06-2010, 03:52 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Hard starts, especially when cold, are usually due to faulty glowplug system or air intrusion or slow cranking.
Why do you believe you have low compression and why do you think your pump is bad?
Old 12-06-2010, 05:33 PM
I replaced the bullet connectors on the glow plugs new plugs all around, and it has a new relay in it, it cycles just fine not as long as i want so i am going to check again, i might need to set my torque screw back to stock also, i have gone over everything but the IP and Head bolts, The engine has 250,000+ on it so that is the reasoning behind the stretched head bolts, the engine is 21.5:1 really high
Old 12-06-2010, 06:47 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
your ip is worn out if it is the original one they are a wear item which is recommened to replace at every 100000 miles same goes for injectors
Old 12-06-2010, 07:11 PM
That is the same thing my dad said, they replaced the ip and injectors at the same time on the old international tractors and it makes a very noticeable difference, that is what i am going to do first, it only cost $362 plus shipping so it isn't very expensive
Old 12-06-2010, 07:45 PM
ah1988's Avatar
ah1988 ah1988 is offline
ah1988 is starting off with a positive reputation.
Where are you buying them from, you are talking about injectors right ?
that seems a little pricey for injectors look at a website called Pensecola diesel ,they have the best prices , if you are talking about injectors .
Old 12-06-2010, 07:51 PM
rodneywar's Avatar
you can get both from penascola diesel
Old 12-06-2010, 08:21 PM
no i already replaced the injectors they where around 160 for 8 and Injector Pump is $362
Old 12-06-2010, 08:43 PM
ah1988's Avatar
I thought you were saying 8 injectors for $362 ,i wasn't thinking you were talking about the ip.
Old 12-07-2010, 08:56 AM
NorthernDiesel's Avatar
NorthernDiesel NorthernDiesel is offline
NorthernDiesel is starting off with a positive reputation.
Just FYI Pensacola has a surplus of our IPs, just bough one, no core charges no need to return the old unit!
Old 12-07-2010, 11:13 AM
I checked there website out, that is where i am going to order it from, do you know if they would sent me a copper head gasket and have turbo piping for our motor?
Initial start after IP/lift pump 119er Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-18-2013 08:29 PM
IP removal Jayme Duty Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 10-09-2011 10:30 PM
1984 6.9 no start, need cliff or rr xing nomorechinajunk Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 07-24-2011 05:17 PM
Changing IP from 6.9 to 7.3-?? 540milotalon Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 07-20-2011 11:06 PM
help with 6.9 rLmcowboy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 05-01-2010 04:43 PM
Tags
73, 73idi, 73l, bolts, ford, gasket, head, heads, ip, powerstroke, replaced, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
