Truck Jerking/Studdering Around 45-50 mph - Ford Truck Enthusiasts Forums
Old 12-06-2010, 02:32 PM
Shane Cummings Shane Cummings is offline
Shane Cummings is starting off with a positive reputation.
Hello all. Here's a little information about my truck. It's a 2000 F-150. Two wheel drive. 5.2 Liter V8. About 133,000 miles on it currently.
Here is the problem I have been having with it recently. Right around 45-50 mph, my truck starts to jerk or studder as I attempt to accelerate gently. It has not been too bad, but it has been prevalent for the past few months. Yesterday, after an 8 hour drive on highways, when I got back onto a regular road, the truck would jerk/studder around 45 mph and it was so bad that I could not drive past 45 mph.
It does not always happen when I drive, but now it is occurring more frequently. I want to bring it into the shop, but want to hear what you guys have to say about this problem first. Thanks!
Old 12-07-2010, 12:23 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Is the check engine light on? If so can you have the codes read?
Old 12-07-2010, 09:45 PM
Nope, the Check Engine light is not on.
Old 12-07-2010, 11:34 PM
Outdoors4life Outdoors4life is offline
Outdoors4life is starting off with a positive reputation.
Even though the CE light is not on there may still be a code. Last week my #8 cylinder was not firing and it threw a code but did not turn the CE light on. Try checking for a code anyways.
Old 12-08-2010, 02:39 AM
How do I check for a code?
Old 12-08-2010, 06:17 AM
Need a code reader. Some auto parts stores will check it for free.
Old 12-09-2010, 12:24 AM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You may never get a code from the issue.
The problem is one or more faulty coils that are "not" hard faults so will not set a code you can see with a reader or see a light from.
Only other way is to use a good mid level "Scanner" to trap the fault or have the coils stress tested by a dealer to find any with low output.
Fyi to all: If you have any tendency to shudder under light loads at anythime, there is a high likleyhood of a low output coil.
Reason: Under low speed and light throttle on and off, the EGR system operation causes very lean air/fuel ratios that requires higher coil voltage to fire.
If one coil has low output, that cylinder will missfire until a shiftdown, higher throttle or any action causes the air/fuel ratio to become richer allowing the coil to fire again.
Then the shudder goes away until the next time.
This temporary condition does not set a code.
Good luck.
Old 12-09-2010, 09:07 PM
CharlieBravo CharlieBravo is offline
CharlieBravo is starting off with a positive reputation.
Get a scanner that can read any "pending" codes. These do not always trigger the CEL.
My 97 F150 had the exact sysmptoms you describe. Under light load at approx 40-45 the transmission went to bucking and got worse over time.
Only with the scanner was I able to get to the root cause. A cyl 3 misfire. Turned out to be the plug wire. 5$ fix.
Old 12-10-2010, 07:12 AM
97flairside 97flairside is offline
97flairside is starting off with a positive reputation.
Wait, so you were experiencing what felt like the transmission bucking or slamming around and it turned out to be the coils? I am experiencing the exact samething, happens usually when under load or cruising. It gets so bad that i have to wait for the rpms to stop dancing on the guage before I can continue. Happened 5 times today alone trying to get to work.
If I have a 4.6L with the 2 coil packs, could I be experiencing the problem with misfiring?
Old 12-10-2010, 08:28 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
Don't rule out torque converter shudder. Has the trans fluid ever been changed? Changing the fluid usually cures it.
Old 12-10-2010, 08:39 AM
oh this is wayyyyy beyond torque converter shudder. I've felt that. I did have the fluid changed back in October 2008, about 25,000 miles ago.
Old 12-10-2010, 08:09 PM
GET THE SCANNER!!!!!!!!
Throwing parts at the problem will nor resolve! I too have the 4.6. The bucking was caused by a bad plug wire. I thought it was the tranny as well. Mine has 260k and was thinking tranny rebuild.
The CEL never came on. The p0303 code would show as pending and would go away a few seconds later. Drove me nuts looking for the problem. The scanner solved the mystery in a few seconds.
Old 12-10-2010, 08:16 PM
Agree.
Get off the transmission shudder kick for this kind of drivability fault.
The hint is 45 to 60 mph and light throttle application.
Old 12-10-2010, 09:14 PM
an autozone scanner will be able to pull up pending codes?
Old 12-11-2010, 11:37 AM
Another Question........
If you turn off OD does the shudder still occur? Mine was caused by the OD dropping and shifting back.
HELP roushchickv8 2004 - 2008 F150 6 08-04-2015 12:51 PM
06 f150 5.4 jerking at 45-50 trucks12345 2004 - 2008 F150 6 02-19-2015 10:09 AM
Tranny Studdering, Shaking Almost.. WTF? Fusion7.3 1999 to 2016 Super Duty 4 05-29-2014 03:28 PM
Jerking/Studder Confusion mblanken881 6.0L Power Stroke Diesel 43 01-17-2012 10:27 PM
2001 Ranger with idle hesitation rangerchief Ranger & B-Series 6 02-27-2005 10:59 PM
Tags
2003, 45, 4550, 46, 62, 64, diesel, expedition, f150, ford, jerk, jerking, mph, powerstroke, skip, studdering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
