Truck Jerking/Studdering Around 45-50 mph
Hello all. Here's a little information about my truck. It's a 2000 F-150. Two wheel drive. 5.2 Liter V8. About 133,000 miles on it currently.
Here is the problem I have been having with it recently. Right around 45-50 mph, my truck starts to jerk or studder as I attempt to accelerate gently. It has not been too bad, but it has been prevalent for the past few months. Yesterday, after an 8 hour drive on highways, when I got back onto a regular road, the truck would jerk/studder around 45 mph and it was so bad that I could not drive past 45 mph.
It does not always happen when I drive, but now it is occurring more frequently. I want to bring it into the shop, but want to hear what you guys have to say about this problem first. Thanks!
You may never get a code from the issue.
The problem is one or more faulty coils that are "not" hard faults so will not set a code you can see with a reader or see a light from.
Only other way is to use a good mid level "Scanner" to trap the fault or have the coils stress tested by a dealer to find any with low output.
Fyi to all: If you have any tendency to shudder under light loads at anythime, there is a high likleyhood of a low output coil.
Reason: Under low speed and light throttle on and off, the EGR system operation causes very lean air/fuel ratios that requires higher coil voltage to fire.
If one coil has low output, that cylinder will missfire until a shiftdown, higher throttle or any action causes the air/fuel ratio to become richer allowing the coil to fire again.
Then the shudder goes away until the next time.
This temporary condition does not set a code.
Good luck.
Good luck.
The following users liked this post:
Get a scanner that can read any "pending" codes. These do not always trigger the CEL.
My 97 F150 had the exact sysmptoms you describe. Under light load at approx 40-45 the transmission went to bucking and got worse over time.
Only with the scanner was I able to get to the root cause. A cyl 3 misfire. Turned out to be the plug wire. 5$ fix.
If I have a 4.6L with the 2 coil packs, could I be experiencing the problem with misfiring?
GET THE SCANNER!!!!!!!!
Throwing parts at the problem will nor resolve! I too have the 4.6. The bucking was caused by a bad plug wire. I thought it was the tranny as well. Mine has 260k and was thinking tranny rebuild.
The CEL never came on. The p0303 code would show as pending and would go away a few seconds later. Drove me nuts looking for the problem. The scanner solved the mystery in a few seconds.
