How do I tell if I have Remote Keyless Entry - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-06-2010, 01:25 PM
davidkstyler's Avatar
davidkstyler davidkstyler is offline
davidkstyler has a good reputation on FTE.davidkstyler has a good reputation on FTE.
Just bought a used 2005 F250 with a 6.0 PSD.
It has electric door locks but I was only given a standard key.
Q1. Are there trucks without Remote Keyless Entry?
Q2. How do I tell if the keyless receiver is installed in the truck?
Q3. Is there a way to unlock all the locks with the key in the door?
Old 12-06-2010, 09:01 PM
cliles55's Avatar
cliles55 cliles55 is offline
cliles55 is starting off with a positive reputation.
I got this from the F150.net website. Perhaps the rapid on/off of the ignition switch will tell you if you have remote capability or not.
<TABLE style="BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 borderColor=#111111 cellPadding=0 width="100%" itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD width="100%" itxtvisited="1">How to reprogram your keyless entry remote controls (97-up)
</TD><TD width="100%" itxtvisited="1"></TD></TR></TBODY></TABLE>
It is necessary to have ALL (maximum of four-original and/or new) of your remote transmitters available prior to beginning this procedure
To program the transmitters yourself:
  1. <LI itxtvisited="1">Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position. <LI itxtvisited="1">The doors will lock/unlock to confirm that programming mode has been entered. <LI itxtvisited="1">Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.) <LI itxtvisited="1">Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
  2. When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Just a note, my '99 F150 had electric locks but after the on/off sequence, they didn't lock/unlock (because I didn't have the module). Just to make sure, I checked my wife's Escort (which did have remote lock/unlock); the procedure above worked.
If the doors don't lock/unlock, you don't have the remote module.
Hope this helps,
Curt
Old 12-06-2010, 09:22 PM
husker's Avatar
husker husker is online now
husker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud of
Do the check, but you probably have the remotes and just need to pick up a remote and program it. That is what I did when I got my '01 a bunch of years ago.
Old 12-06-2010, 09:23 PM
Powerstroker_18 Powerstroker_18 is offline
Powerstroker_18 is starting off with a positive reputation.
I had actually just checked into this earlier today when ordering parts from Ford. My question is can a keyless entry module be added? Are the trucks pre-wired for it?
Old 12-06-2010, 10:51 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
It appears your trim level is an XL. If so, it's unlikely that it has RKE.
If your trim level is Lariat, it likely does have it.
If an XLT, it's a toss-up.
Pop
Old 12-06-2010, 11:03 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
Quote:
It is with heavy heart that I have to, at present time, agree with the answer of "NO"...
I'm still looking into it though... if the factory can install it, anyone can.
Old 12-07-2010, 05:56 AM
cliles55's Avatar
Assuming you don't have the module after doing the check in my first reply, I'd recommend going to a stereo store that offers RKE to get a price quote. That will a) tell you if the wiring is existing and b) give you a hunch on how much Ford will charge you (stereo shop times at least 2 would be my guess).
And, no, you can't unlock all the locks with the key in the door; you could with a key pad or remote.
Old 12-07-2010, 08:06 AM
I tried to do the above tests last night and couldn't get the locks to operate. I guess I don't have the module, just the electric locks.
I did find this at Sam's. Bulldog Security KE1702 Remote Keyless Entry - Sam's Club Has anyone used one of these?
Old 12-07-2010, 06:42 PM
cliles55's Avatar
The kit from Sam's appears to be 2 high-powered transmitter; no module is mentioned.
Old 12-07-2010, 08:38 PM
If you use the part #KE1702 to search on the Bulldog website you get this page
Bulldog Security. Model KE1702 Vehicle Keyless Entry System
It shows a module that has to be wired in.
Old 02-10-2016, 06:41 AM
Zee1978 Zee1978 is offline
Zee1978 is starting off with a positive reputation.
RKE
Look at your dashboard, if you have a blinking sensor you have a RKE vehicle.
Old 02-10-2016, 07:45 AM
wrvond's Avatar
wrvond wrvond is offline
wrvond has a good reputation on FTE.wrvond has a good reputation on FTE.wrvond has a good reputation on FTE.
One way to tell if a truck has factory RKE is to look at the front passenger door handle. The exterior door lock is deleted when the RKE option is selected. If you have a keyhole on the passenger door, you don't have factory RKE.
Old 01-30-2017, 09:33 PM
dummuck dummuck is offline
dummuck is starting off with a positive reputation.
Key unlocking all
I have a 1996 Ford Explorer XLT and it doesnt have a keyless inter but if you turn the key to the right two times while it is in the door it does unlock all the doors.
Old 01-31-2017, 02:31 PM
TexasRebel's Avatar
Might be time to update this thread. I was successfully able to enable factory RKE on my 2008 F250 XL without adding any aftermarket parts. I only had to buy the fobs.
For the 2008s (maybe others, too) you can use FORScan to modify the as-built data to enable RKE. Like I've always said, the SJB is identical on every pickup, the RKE transceiver is present, but disabled.
It's just a matter of flipping two bits to match the w/RKE vehicles.
Old 01-31-2017, 10:41 PM
Something your dealer won't tell you......
Pop
99 F250 Keyless Remote Entry ? Haveyoudrivn1lately? 1999 to 2016 Super Duty 25 10-26-2014 05:18 PM
Remote keyless entry 61 uni 1999 - 2003 7.3L Power Stroke Diesel 5 12-30-2008 08:11 AM
How can I tell if my truck came with keyless entry remotes? viperbluelx 1999 to 2016 Super Duty 4 05-31-2007 09:06 AM
Any ideas on programming remotes? waldreps 1987 - 1996 F150 & Larger F-Series Trucks 5 12-23-2006 09:50 AM
Do all 2002 F250 XLT's have keyless entry? GATRUCK Electrical Systems/Wiring 2 08-20-2006 10:22 PM
Tags
2001, 97, check, entree, entry, escape, f150, f250, ford, keylees, keyless, mod, remote, remoye, rke, transmitting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
