my truck came with the bellowed boots on the plenums. It's stock too. weird. Hey, do you carry the square o ring for the compressor outlet? I'll get that from you tonight too if so.
Not on the site, but I have them.
Originally Posted by strokin'_tatsch
Stock boots on my truck were hump boots... Any chance they were hump boots from '94.5-'95 then in '96 changed to straight? Maybe an "updated" part?
They used the same design until the 99.5 and up Super Duties, except I think in 97 when they were straight boots.
Partsguyed has the clamps but not sure if I need the 1-1/2" or 1-3/4"...
F5TZ8287A is the 1-1/2"
F5TZ8287B is the 1-3/4"
The reason I want a new one is that mine doesn't seem to tighten down all the way, even after getting it tight as it will go the spider still moves around a little.
Ok, when I looked those part numbers up they were listed as radiator hose clamps on Ed's website... and one was discontinued.
So I'm really not sure what to think about them...
I have this number for the OEM CLAMP (marmon or V clamp)
F4TZ-8287-B
Then how do you explain the straight boots on my late 96???
Sorry, I could be wrong. I was going on my personal experience, not any written down info. My dads early 97 had "hump" boots, my late 97 truck had straight boots, and I have looked at several others that backed up my theory.
What is your manufacture date? Is it a California model?
