5.0 radiator capacity ? - Ford Truck Enthusiasts Forums
Old 12-05-2010, 11:52 PM
fonzie fonzie is offline
fonzie is starting off with a positive reputation.
Question 5.0 radiator capacity ?
Hi, new to the forum. I tried some searchs and did not find any answers but I may have missed it, sorry.
I have a 93, F150 with a 5.0. I have drained the coolant twice and only seem to get 8 qts (50/50) back into her, the manual calls for 14. I dont get it. She doesnt overheat and actually only ever gets to the "O" in normal. When draining, I know the thermostat opened cuz I ran it with the system open to completely flush the system and the temp got up to "m" and I saw some steam before I shut her down. After filling with e gallon of coolant and a gallon of water, I ran her for about 10 miles, so I am sure the thermostat opened up. She runs fine. Any thoughts?
Old 12-05-2010, 11:59 PM
fairlane68's Avatar
fairlane68 fairlane68 is offline
fairlane68 is starting off with a positive reputation.
The capacity for the entire cooling system is 14 quarts. Not the radiator. You still have the water jackets in the block and the heater core, plus what's in the hoses and the water pump. If it's not overheating and the gauge reads normal, why are you even bothering with it?
Gooch's Radiator/Engine Backflush Procedure and Coolant Information Stewart_H 1999 - 2003 7.3L Power Stroke Diesel 306 11-29-2016 04:21 PM
1991 ford bronco 302 running hot Berardini2121 1978 - 1996 Big Bronco 8 04-23-2016 12:49 AM
Radiator flush question! meierw1 1999 - 2003 7.3L Power Stroke Diesel 8 07-01-2012 11:07 AM
How long to get air out of cooling system after a fluid swap? Piolet 6.0L Power Stroke Diesel 1 04-09-2012 08:33 PM
4.2L coolant blockage? bh1402 1997 - 2003 F150 4 01-31-2012 06:59 PM
Tags
1987, 1994, 1996, 50, 77, 96, broncol, capacities, capacity, coolant, f150, ford, gal, radiator, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
