Oil Change capacities 1997 F250 LD 5.4 Liter
Old 12-05-2010, 05:23 PM
97F250LD4X's Avatar
97F250LD4X
97F250LD4X is offline
Whats the oil change capacity(with filter change) supposed to be on a 1997 Ford F 250 LD 4X4 with a 5.4 liter engine?
Ive read its 6 qts. So I bought a 5 quart jug of oil with an additional quart.
I do the oil change,fire up the engine,let it circulate and shut the engine off,allowing about 1/2 hour for the oil to drain back into the pan. I check the oil and im only 1/2 way up on the dipstick...What gives?
Also whats the OEM recommended viscosity of oil supposed to be. Ive owned the truck for 5+ years and I can only remember using 5W-30. Everywhere I read now,it says the recommended oil is supposed to be 5W-20. Im confused. Was I putting in the wrong oil all along,or is this something that changed only recently?
Im not too concerned,running 5W-30 instead of the 5W-20 wont hurt anything... will it?
Old 12-05-2010, 05:25 PM
n5926g's Avatar
n5926g
n5926g is offline
Halfway into the "good" area is correct.
Old 12-05-2010, 06:22 PM
Ron W.'s Avatar
Ron W.
Ron W. is offline
5w30 was what it had in it from the factory, and about 1/2 way up in the "hash marked" portion of the dipstick is correct. 6 quarts with filter.
Old 12-21-2010, 03:51 PM
Jonnyih's Avatar
Jonnyih
Jonnyih is offline
i use 5w30 and put 6qts in and all is good, book spec isn't what ya go by anyway, that'll get ya close, just so that the oil level is above add on stick and below full, i buy 5 gal at a time and fill er up to just below full and its just over 6qts
Old 12-23-2010, 11:48 PM
tofer76's Avatar
tofer76
tofer76 is offline
do you have the relocation kit on yours i do and it takes 7 with filter change to get to the green zone that is half to 3/4 up the hashh marks and i use 10 w 40
RJL1
07-21-2017 01:38 PM
Guy73
Fifth Wheel & Gooseneck RV Towing
22
08-03-2016 10:59 PM
Ronnief150man
04-17-2016 12:59 PM
SteevenH
1997 - 2003 F150
01-07-2010 03:43 PM
tonyford
Escape & Escape Hybrid
01-04-2006 12:25 PM
Quick Reply: Oil Change capacities 1997 F250 LD 5.4 Liter
