You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Ok hears the deal, I have a 89' f 250 7.3, with 5 spd, 4.11 rears, 210,000 miles on it, 2 newer bats,returnline kit with extra vitons orings, couple spare rims some with tires on them.newer cluch and slave cylinder. new fuel filter,one full tank and one is at half.
The problem is the left rear axle bearings went on it and now the hub socket to take the bearing nut out is stuck in the axle, So it will need to be towed, as of right now you could put the wheel back on and lift it from the back to tow. if there is any intrest or questions please feel free to ask. The truck is located in south NJ. Thanks.. Dan,
dude i am sorry the gf said no i was gonna get the truck and strip it down for parts like the trans and engine mostly she said its too much money for us to spend right now
__________________
Ronnie
1996 f350 4x4 7.3 psd srw 4.10ls, mods- dp tuner f-6 ,bdp eletric fuel, 90 gallon main tank, hpx, 6637, 3 inch dp to 5 inch pipe, t500, casserly stage 1s, intercooler, stock housing with nbs wheel, 120v idm Built tranny with sure cure kit and valair triple disc converter, tranny cooler inside the bumper, hydroboost with f450 brake pedal adjustable proportioning valve 4 inch lift with 35s, sd tensioner 08 rear diff cover
