315/75R16 on stock wheel ? - Ford Truck Enthusiasts Forums
Old 12-05-2010, 12:44 PM
njneer1's Avatar
njneer1 njneer1 is offline
njneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to all
Anyone have any 315's on stock wheels ? got pics ? trying to figure out if I need to buy wider rims......think they will fit ??
Old 12-05-2010, 05:15 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
They do fit, I know, I have them...Mine is a 2wd, so I had to have a 6 inch lift for them to clear. But yours being a 4wd, you would need a 3-4 inch lift to clear them. Bottom line: they fit, but you need some lift...the largest you can clear without a lift and stock rims are 305/70/16 tires.
Old 12-05-2010, 05:42 PM
njneer1's Avatar
I just put rough country F350 2.5 " leveling springs under the front and 2" add a leaf on the rear...think It will be ok with 315's ? That is the pic now...you can compare to the profile pic
Old 12-05-2010, 08:56 PM
nunomad nunomad is offline
nunomad is starting off with a positive reputation.
I have a 03 limited 4x4, with a 2" lift front and back, and just put a set of Mickey Thompson ATZ plus's 315/75/16 on factory limited rims and fit fine. The rims are 7" wide, but went on easy.I do only have about 1" of clearance from front bumper back to corner of tire and same from rear lower corner of wheel well to rear corner of tire when turning corners. I did have BF Goodrich's on but with the squareness of the corners of the tires the clearance I do have wouldn't be there that I have with the rounded corners of the Mickeys.
If you plan on any off roading-BEWARE. Only my .02.Nunomad
Old 12-05-2010, 09:59 PM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Neil, I added 6 pic's to my 'various' album. ProComp all terrains. Stock rims. A little bailing wire on the inner fender and you're rollin'.
http://www.ford-trucks.com/forums/me...-a-little.html
Old 12-05-2010, 11:02 PM
saz2686's Avatar
saz2686 saz2686 is offline
saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.
they will fit
i have an excursion 4x4. i added two leaf springs on the front (about 4" of lift) and three leafs in rear. i mounted 315/75/16 nitto all terrain on the factory wheels. i have never had tire rub while driving even off road. the tires do rub the leaf springs while fully turned. just get in habbit off not turning extreme!
Old 12-06-2010, 10:38 PM
njneer1's Avatar
Quote:
Thanks man !! and thanks to you all !!
Old 12-07-2010, 12:28 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
The 315/75R-16 will physically fit on a 7" wide wheel but the "design rim width" for that tire size is an 8.5" wheel. Not many 8.5 inch wheel manufacturers out there so 8.0 is close enough. Not saying it won't work on a 7, just not the ideal situation.
Old 01-11-2014, 01:36 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Ford Truck Enthusiasts Forums - wpnaes's Album: Various Ex Work - Picture
I saw all your individual pics, did the K&N filter, special bumpstops front and rear, dual batteries, and double steering damper do anything special? I like that 56 Ford, I hope that wasn't a for sale sign on it.
Old 01-11-2014, 06:48 PM
sandfarmer's Avatar
sandfarmer sandfarmer is offline
sandfarmer is gaining momentum as a positive member of FTE.
315 Toyo Open Country AT 2's
Old 01-11-2014, 06:52 PM
sandfarmer's Avatar
Quote:
I think that's about what mine has too, do it, it will work fine. Mine rub the front leaf springs when turned to full lock either way but it's not too hard to deal with. By the way mine DID clear the front bumper when I had the stock bumper on, just put the Ranch Hand on this week.
My new $100 Bronco/snorkel and redhead on my old Bronco njneer1 1978 - 1996 Big Bronco 29 02-07-2013 11:00 AM
Found this sign on the trail this past weekend ! njneer1 Offroad & 4x4 50 11-17-2012 08:31 AM
315's installed... njneer1 Excursion - King of SUVs 15 07-18-2011 09:53 PM
Brush guard maker ? njneer1 1978 - 1996 Big Bronco 7 06-28-2011 08:58 PM
cluster njneer1 1978 - 1996 Big Bronco 3 04-10-2011 07:51 PM
Tags
2005, 285, 315, 31575r16, 4wd, 75, excursion, fit, ford, r16, rim, rims, stock, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
