2002 F-350 Fan Blower Motor only High Speed? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-05-2010, 12:31 PM
RRRAVEN RRRAVEN is offline
RRRAVEN is starting off with a positive reputation.
Hi-
My fan blower motor only works in the high speed position. I thought I saw a prior post on this but can't find it. The post mentioned that there is a blower motor resistor located somewhere behind the glove box or passenger kick panel?, and that this resistor needs to be changed. I have looked but can't locate it. Can anyone shed some light on this? Winter is quickly on it's way here in New Hampshire so I would like to get this problem corrected.
Thanx-
RRRAVEN
2002 F-350 V10
Old 12-05-2010, 12:42 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
The blower motor resistor is usually located under the hood next to the blower motor. U will see the little hose that cools the actual motor and the resistor is immediately next to it with 2 screws holding it in.
Blower Motor Jack Legged stevieb_wv 1987 - 1996 F150 & Larger F-Series Trucks 1 10-02-2014 10:25 AM
blower motor resistor dfiske Cooling, Heating, Ventilation & A/C 34 11-27-2013 01:32 AM
A/C Blower Motor Not working at all? dfoxengr Excursion - King of SUVs 3 07-29-2012 10:01 PM
Blower motor resistor 88 ranger w/ac Marky48170 Cooling, Heating, Ventilation & A/C 4 09-15-2011 12:10 AM
Blower Motor Resistor Location '08 Escape... 2002sport Escape & Escape Hybrid 4 10-23-2010 12:01 PM
Tags
2000, 250, 99, blower, f150, f250, f350, fan, ford, high, located, motor, problems, sd, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
