1988 F150 4x4 XLT Lariat Steering Column issues - Ford Truck Enthusiasts Forums
Old 12-05-2010, 11:03 AM
garyed08 garyed08 is offline
garyed08 is starting off with a positive reputation.
im having some issues with my steering column. i am gonna replace. what years do they work from. are the plugs only for the 87-92 or will a 93-96 work as well. i know the steering wheels are different but i was wondering if it would work in my truck and still be able to use the column and change out the wheel
Old 12-06-2010, 06:10 AM
Old 12-06-2010, 11:16 AM
IDI Diesel IDI Diesel is offline
IDI Diesel is gaining momentum as a positive member of FTE.IDI Diesel is gaining momentum as a positive member of FTE.
the plugs will be differant after 93. make sure that the new colum is for the same style tran you have. If not you will run into some problems with linkages. Its fine to put a auto trans colum into a manual trans truck. If your truck has cruise control make sure the new coullum has it also because its near impossible to rewire a collum. And just check the universal joint on the new colum for excessive play because in my state you can fail inspection for that
Old 12-06-2010, 11:34 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
what is actually wrong with the column? Sometimes fixing them can be a pain but replacing them can cost more and last 1/2 as long as just fixing them... use a 87-91 column with the same tranny set up like stated above make sure you find a xl or xlt column! if you get a custom column it won't have tilt or cruise...
Old 12-06-2010, 08:30 PM
the whole knuckle inside is busted. well beyond rebuilding. i can get a used one here at a local JY for about 20 bucks. Has Plenty of 87-91s. Thanks Guys
Steering Column issues djmichael24951 1987 - 1996 F150 & Larger F-Series Trucks 6 12-06-2015 05:34 PM
power steering conversion HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 10 07-05-2015 03:10 PM
Steering column confusion falcain 1961 - 1966 F-100 & Larger F-Series Trucks 2 01-11-2015 11:54 PM
steering column issue 2005f-150 1987 - 1996 F150 & Larger F-Series Trucks 8 05-07-2012 08:50 PM
steering column jmikeyj4 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-05-2011 07:32 PM
Tags
1988, 351m, 4x4, collium, column, f150, ford, fuel, lariat, problems, pump, stearing, steering, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
