Can't shift my truck Into gear...stuck In neutral - Ford Truck Enthusiasts Forums
Old 12-04-2010, 10:40 PM
robs01f250 robs01f250 is offline
robs01f250 is gaining momentum as a positive member of FTE.
Well....after having my little brother change the batteries in my truck while I was out of town he drove it back home. He went out to get in it to leave and it wouldn't go into gear. It seems it is stuck between 1st and 2nd and won't move up,down,left, or right. It won't go into any gear whether the truck is running or not. I have done a little research as I am out of town and I know that the 2000 and up have the upgraded shift fork. I know that the hydraulics are good. Any ideas??
Old 12-04-2010, 10:41 PM
After doing a little more research I was wondering if the shift fork and the clutch fork are the same thing?
Old 12-04-2010, 11:38 PM
Visseroth's Avatar
Visseroth Visseroth is offline
Visseroth has a good reputation on FTE.Visseroth has a good reputation on FTE.
Manual or auto?
If it's a manual which it does sound like because you mentioned the clutch fork then it sounds like the syncros got jammed up.
That and an auto won't allow you to start while being stuck between gears.
Sounds like the tranny needs to come out unfortunately.
Old 12-04-2010, 11:43 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
The clutch fork is definitely the part that disengages the clutch from the transmission when the pedal is pressed. Its located inside the bellhousing. It will not effect whether or not your shifter moves left to right in nuetral. It will cause problems going into gear if there is a problem with it.
The shifter fork is what slides the gears into the various positons when u move the shifter. I think it rides in the bottom of the shifter handle in a ball/socket type joint. Its internal to the transmission and what allows 12345 & r by lining up the various ratios inside the transmission when selected.
It could be shifter fork or maybe some kind of jam in the actual linkage below the shifter itself. Thats all i can offer. Hopefully one of the other guys will know more about how they usually fail. Everything here is usually automatic.
Old 12-04-2010, 11:45 PM
Quote:
Originally Posted by Visseroth View Post
Manual or auto?
Probably b/c he is using differnt computer, it dumped his signature. Here is his normal sig.
<DD id=signature>2001 F250 7.3 6speed FX4, 2.5in spring leveling kit
6637, foil delete, painted IC pipes
Isspro boost, pyro, DP f5 gauge
DP Tuner 80e, 120r, and 140 SMOKE
BF Goodrich AT 295/75/16, MKO 5'' straight piped
Bull Bar and camo seat covers, TRAIN HORNS</DD>
Old 12-06-2010, 11:29 AM
Well I got back in town and got to looking at my truck and it seemed to be stuck right where I said it was. I took the slave cylinder out and looked in the bell housing and couldnt see anything out of the ordinary. Got back in the truck and fired it up and was trying to get into any gear. Well, I found 1st and limped most of the way home. When I got close to my house I changed gears and found all the gears with no problem. It is somewhat hard to go from 1st to second, but every other gear seems ok. I am going to check out the linkage to see if is has binded up on me
Old 12-06-2010, 11:35 AM
When I wrote linkage, i did not mean linkage as far as external to transmission as a lot of trucks have. I figure you probably know that transmission better than me but I did not want to send u on a wild goose chase if not. You can check that joint at the top of the transmission but it almost sounds like a synchronizer issue or shift fork issue.
Old 12-06-2010, 11:43 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Sounds like a broken 1,2 slider to me.
Old 12-06-2010, 12:38 PM
Does I have to pull the transmission to fix this problem?
Old 12-06-2010, 02:52 PM
Yes, it requires a tranny rebuild.
But first, remove the shifter lever from the top of the trans and look down inside.
There was a very recent thread here on FTE about somebody having problems shifting and it ended up being a broken roll pin that secured the inner selector lever to the selector rod.
I cannot remember the title of that thread, perhaps someone else can post it?
Old 12-06-2010, 03:42 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
http://www.ford-trucks.com/forums/10...ml#post9627760
There is the problem I was having. If the roll pin on the main shift rail driver fractures like mine, it can do all kinds of weird things. Like Kwik said, might want to look at the shift driver from the top and see if there is anything going on with the pins
Old 12-06-2010, 07:23 PM
That's the thread I was talking about, thanks for posting.
C6 changes shift points 406angler 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-03-2014 04:49 PM
Anyone have these 4R100 issues before? rlebar 1999 - 2003 7.3L Power Stroke Diesel 14 02-13-2014 05:27 PM
Won't come out of park 83FordMan2012 1997-2006 Expedition & Navigator 10 01-06-2013 01:24 AM
Won't shift out of park. hubler13f 1999 to 2016 Super Duty 2 06-20-2010 03:12 PM
1996 bronco transmission pshockley 1978 - 1996 Big Bronco 1 04-01-2006 12:50 AM
Tags
250, automatic, f150, f250, ford, gear, lever, neutral, problems, shift, starting, stick, stuck, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
