Leaky rear pinion seal
#31
on
How hard it is to turn the yoke after the nut is tightened. Just wiggle it back and forth after each increment of tightening until there is A LITTLE DRAG on it, that's all there is to it but the nut has to be tight at that time also.
#33
Jeff, on Powerblock TV, Ian reviews the process. Not exactly our situation, but he explains it well. Let me try to find that episode for you.
#36
You've confused this thread that has zero friction, with the other thread where people are posting differing opinions.
Stewart
#39
on
Usually you can use the old one like it is because it has some springiness to it and as the bearings wear that also gives you more crush sleeve length, also you could put a shim or washer on the end of it and squeeze er' some more. As long as the nut gets tight that's all you need and the ONLY purpose of the crush sleeve is to give the nut something to tighten against. You could actually take the sleeve out and use lock-tight on the nut and it would probably stay good.
#40
'69 International Scout Part II | Xtreme 4x4 | PowerBlockTV - Full Episodes
#41
Stewart
#42
on
Was on a very cool Intl Scout 800A (7:37) .
#43
The advice Brent gives is the same advice I get from a veteran mechanic at my friend's auto shop. When I did my pinion seal, I did all the work. When it was time to tighten the nut, I asked for help. The mechanic who specialize in rear ends checked the drag and tighten the nut with a few bursts of impact gun.
EDIT: Maybe he might have measured drag with inch/pound if I would've paid him.
#45
I'm just playing lol.
