Pulling the distributor - Ford Truck Enthusiasts Forums
Old 12-04-2010, 07:38 PM
thatoneguy_10's Avatar
thatoneguy_10 thatoneguy_10 is offline
thatoneguy_10 is starting off with a positive reputation.
I'm bout to install a edelbrock performer intake on my 78' 460. I know I need to pull the distributor but how can I do it to where I can install it back just how it is. I don't know anything about setting the timing so if it can be left like it is that would be really helpful. Thanks for any advice.
Old 12-04-2010, 10:07 PM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
Quote:
You can mark the position of the rotor in relation to the body and then the vacuum advance in relation to the water pump and that should have you pretty close when its dropped back in. Having said that, if you do NOT know how to clock a distributor back into time, I would seriously suggest either having someone else install the intake or seeing if you have a buddy who knows how to do it come by and help you on the install.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
