Bellhousing block plate. - Ford Truck Enthusiasts Forums
Old 12-04-2010, 05:15 PM
6863m 6863m is offline
6863m is starting off with a positive reputation.
I am putting together the parts for the 460 I am putting in the 73 truck. It is an 1986 460 and I am going to buy a flex plate because it was not with the engine. But I also recall someone saying something about a block plate. Is that a part I can just order with the flex plate or is it a junkyard item.
Thanks
Old 12-04-2010, 07:36 PM
MAULMAUL's Avatar
MAULMAUL MAULMAUL is offline
MAULMAUL is gaining momentum as a positive member of FTE.
You can order them for about $70. You can find them in a junkyard but they are in a pisser location to get to unless you just get lucky and find one laying around. I had a link until I deleted it about two weeks ago. Just google 460 block off plate. The price should be $70. It won't look exactly like the factory one. It will be more solid, meaning less spaces cut into it. It is to keep your engine safe in the event your tranny pukes and vise versa.
Old 12-05-2010, 11:18 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
One from a 351M-400 will work too. You just have to cut the cranks hole out a little bigger in it.
Old 12-06-2010, 12:07 PM
I have been looking on the web for the blocking plate but have had no luck. I found the flex plate and ordered the plate but the same company did not have the blocking plate. Does anyone have a site or an address for the blocking plate.
Thanks in advance.
Old 12-08-2010, 07:52 AM
MAULMAUL's Avatar
Try this: KMJ Performance :: Bellhousings :: Bellhousing Accessories :: 460 Big Block Ford Engine Plate
I used this search: RM-8005 460 Big Block Ford Engine Plate
Old 12-08-2010, 04:08 PM
Thanks for the help and it will get me going in the right direction.
Can I change the flex plate without removing the transmission? nicksorenson 1987 - 1996 F150 & Larger F-Series Trucks 7 06-11-2016 10:24 PM
how to remove a flexplate rannaska FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 05-23-2016 11:20 AM
Need help with flexplate tumble72 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-22-2016 03:20 PM
E4OD swap flex plate question Ongoingshow 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-13-2011 05:36 PM
460 bellhousing block plate 6863m 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-06-2010 08:00 PM
Tags
150, 1940, 300, 460, 46l, 54l, bell, bellhousing, block, ford, housing, idi, image, plate, psd, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
