factory jack and accesory question??
My 94.5 F350 had the jack mounted on the passenger fender well and the long rod thingy in front of the radiator when I got it. I thought it was complete until I looked at the driver side fender of my 91 IDI and I noticed a lug nut breaker bar mounted their? I thought everything was missing from my 91 so my question is where was this peice supposed to be on my 94.5? The best I can tell it was probably also mounted on the passenger fender along with the jack.
On my 97 it is mounted right behind the jack, passenger side. You can see a hole where the lug nut end sticks into. From there is goes down a bit behind the jack then back towards the down pipe and through a hole protruding from the frame to secure the lower part. I'll take a picture if you need it.
jiveturkey692000
12-16-2010 10:21 AM
powerstrokedieselfan
10-03-2010 04:29 PM
60RatRod
08-01-2008 10:03 AM
tom9141
10-28-2006 11:59 AM
94.5turbodiesel
11-16-2005 08:40 PM
