2002 Ranger Clutch Problem
I have a Ford Ranger Edge 2002 4.0 v6. Recently while driving my clutch pedal went to the floor, after taking an in depth look at the vehicle I've determined that the clutch was not the issue but signs pointed toward the slave cylinder. I've tried bleeding the system twice now, which will give me clutch back in the vehicle for a limited period of time, however I have recently found a slow leak coming from inside the vehicle, which although i can't see dripping appears to be coming from above the clutch pedal. Would this leak indicate a different problem ie: the master cyl. is leaking not the slave, or should i still be focused on repairing the leak in the slave.
thank you in advance.
frankiethethumper
07-15-2017 09:15 PM
Kapusta
01-13-2017 02:50 PM
bluemtn95ford
1983 - 2012 Ranger & B-Series
04-05-2015 06:37 PM
